Question about Kitchen Ranges
I was cleaning my oven with an oven cleaner it is flipped the safety switch. I have cleaned it all out, let it air overnight and everytime i turn the power back on it flicks the safety switch.
    Scholar:
  • 150 Answers
Caused a short somewhere if you don't have a meter or experience with this stuff call for help if you need tech assist on the trouble shoot give me make and model
Posted on Apr 23, 2008
I have the porcelain coated pans and the kids burnt chilled cheese and just can't seem to get it clean now
You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
  1. Put the pan in your empty kitchen sink.
  2. Spray it on generously with oven cleaner.
  3. Leave it overnight, 8 hours or so.
  4. In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
Apr 02, 2011 | Vacuums
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    How to clean a ge spectra electra xl44 series stove. Just slide door lever from left to right, and turn oven to clean, and forget about it. ???? anything else to do ? Nothing to spray inside oven...
      Self Cleaning
    1. Remove oven racks and soak them in soapy water.
    2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
    3. Let the oven do its work; it will heat for several hours, charring off baked-on foods
    4. Fast Cleaning
    5. 1 Remove oven racks and place them in soapy water to soak.
    6. 2 Preheat oven to 200 degrees.
    7. 3 Turn the oven off and spray the inside with oven cleaner.
    8. 4 Allow to sit for 10 minutes.
    9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    10. 6 Dry with a soft cloth.
    Sep 16, 2010 | Kitchen Ranges
    Can't open oven door after cleaning
    This is a really common problem with a lot of the newer ovens. I don't know the exact model you have, but most Jenn Airs latch code errors is F9. Here are basic steps to reset any model:
    1) You might have the oven scheduled for cleaning. If so, clear that.
    2)You also might have a child safety lock that was put on by accident. If that doesn't work, try to reset the oven cleaner for a minute or two and have it shut off so that it resets.
    3) If none of the above works, go to your breaker box and shut the power off. Give it a minute and flip the power back on. It should reset the electronics.
    On some models with the electronic controls right above the ovens, the self clean ovens get so hot that it sometimes damages the electronic power relay box that is behind the clock. I hope this works for you. If not, leave comments and I will go through how to check the electronics with a voltage tester.
    Dec 19, 2009 | Jenn-Air Ovens
    How to clean inside top of oven above heating element
    FIRST TURN OFF POWER THEN SPRAY TOP WITH OVEN CLEANER AND LEAVE OVERNIGHT THEN CLEAN WITH STRONG PLASTIC BRUSH NOT A WIRE BRUSH AS THIS WOULD CAUSE DAMAGE , WHEN FINISHED CLEANING WASH WITH WARM WATER ,
    Nov 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Easy off ate all enamel off interior of oven
    First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
    Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
    Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
    Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
    Kitchen Ranges Logo
    74 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
