Question about Panasonic DP-8020E Black and White Copier
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this machine worked great with the toner that came with it. I had a new bottle from he first machine so I just emptied it into the bottle from the new machine and cleaned it off and put it back in. Now the new machine is does the same thing the old one was doing. What do you think the problem is maybe bad toner?
  • Panasonic Expert
  • 1,326 Answers
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Posted on Jul 28, 2010
Dear Sir, I have Minolta BizhubPro 950...the problem is dark copies on the paper.....can u give an email address so i can send u the picture problem on my copier machine
check the cleaning blade assy. and also check the charge corona assy. last time a PM was done on the machine?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 16, 2014 | Konica Minolta Bizhub 222 Black and White...
Paper comes out black
Check the image unit. And check the charge grid on the top of the drum. also check the three little springs that the top of the machine comes down on under the image unit.
Feb 28, 2014 | Minolta EP1031/1031F CS/PRO Copier
Minolta bizhub 222 dark copies
Whenever you ask about any problem please explain in detail.There are couple of reasons behind the above mentioned problem.Its not clear that copies are all black (full black) or just dark in print density? or its giving a dark shade? As per asked question, the solution is Check the followings1-Scanner mirrors are dirty2-Drum is damaged or faulty3-Charging corona 4-LD unit5-Developer
Aug 19, 2011 | Konica Minolta Bizhub 222 Black and White...
Minolta di181 says paper jam no. 6. Where is no.
On your operation panel is a graphic of the copier with numbers on it. The 6 area is on the right side of the copier. Look at the door labeled R1. This is the area as well as the 2 paper trays. I would check those as well.
Oct 20, 2009 | Office Equipment & Supplies
DI181 ERROR C1300
The motor in side the print head error the print head houses a motor which scans the LASER across the drum, can't get just a motor you get the entire print head try this site if they still have them you have a legacy Minolta machine now Konica Minolta. Open close the front door to reset.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 25, 2009 | Minolta DiALTA Di181 Printer
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Jul 30, 2008 | Minolta DiALTA Di181 Printer
Konica 1216 Phocopier, big problem!!!
MY COPIER FLASHES P.26 CODE WHAT I DO?
OR ISSUED TO RETIFY IT
Apr 15, 2008 | Konica Minolta DiALTA CF910 Copier
Panasonic DP-8020E Black and White Copier Logo
136 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
