Question about Equator EZ 3720 CEE
Machine not drying
The machine is not drying anymore. We are using fabric softener, and not loading the drum with a lot of clothes. It comes out the same way than after being washed, but only a little hotter. Please help us!! Should we hire somebody to come repair the dryer or could we fix it by ourselves?
  • 5,081 Answers
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.
Posted on Jul 28, 2010
My washing smells after a wash, but the washing machine drum does not smell.
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Jul 02, 2014 | Hotpoint Aquarius WD63 Front Load...
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Last load of washing has lots of black dirty marks on them
It would appear that the drum seal and bearings have failed. If you have been doing constant cold water washing and using fabric softener and the machine is over 5 years old, I would say its time for a new machine. There are not many that last past 5 years any more especially with cold water and fabric softener usage. Bearing and seal replacement can be very expensive. The drum shaft (Spider assembly) will probably need changing as well.
Dec 21, 2017 | Zanussi FLA1101W Front Load Washer
Moldy smell
A solution/suggestion from the internet:
Another:
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
May 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Smelly clothes
Another:
And dont forget to rate me pl. Merry Xmas to you too.
Dec 22, 2007 | Washing Machines
Black spots
It should clean the machine and move out the bad smell or grease.
Another:
I believe Whole Foods sells them and they are also on the internet at Maggiessoapnuts.com
Sep 19, 2007 | Splendide 2000S Vented Washer/Dryer
Washing Machine Smell
Sep 16, 2007 | Washing Machines
Problem with my washer
A solution from the internet: Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
Sep 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Clothes coming out dirty.
A solution from the internet: Make a boil wash (with no clothes and detergents), put into the soap dispenser a cup of bicarbonate of soda.It should clean the machine and remove the bad smell. Another: I have a front loading machine also and am not willing to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found a solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soapnuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine. Fixya is real cool.....
Sep 12, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Aug 10, 2007 | LG WM0642H Front Load
Equator EZ 3720 CEE Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
