I have a Chanchong lcd tv modelCHL2643A. It came
I have a Chanchong lcd tv modelCHL2643A. It came on automatically this morning as it does every morning and I turned it off using the easy remote. i went to turn it on this evening and neither remote would work. have checked the batteries in each on and they are fine. the tv was purchased about 6 weeks ago. it will only turn on using the buttons manually. i am at a loss as to what has happened and was wondering if you have any suggestions. i have turned it on and off using the powerpoint as well as the manual buttons. in a bother as I have had neck surgery and my family got it for me for mothers day to help me see tv easier. any ideas??? many thanks
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Do a hard reset to his set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 01, 2017
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: Vizio 50 inch plasma -- remote not working
Reset the remote control and the TV at the same time and this may work. Step 1; First unplug the TV from the wall/surge protector. Wait 5 Min. while your wait here is step 2; You take the batteries out of the remote>then press down on every button 2 Times>replace the batteries in the remote, after the 5min. go ahead and plug the TV in and try it again. If this does not work then you need a new remote control.
Posted on Sep 22, 2007
  • 453 Answers
SOURCE: samsung tv won't turn on
do u hav e back light , if u do u may have a bad signal board ,need model #
Posted on Nov 07, 2008
  • 736 Answers
SOURCE: Remote not turning the Zenith Plasma Display Panel TV on/off.
the remotes are usually multi function .. that is, they can control more than just the TV .. make sure TV mode is selected ... if its in VCR mode or Cable or whatever then it wont control the TV .. if its a programmable remote then it may have lost its program and would have to be set up again ... if its the original that came with the tv then that shouldnt happen . once in a while but not often i see a bad LED (at the tip of the remote) ... those are infra red so you cant see the light beam but a digital camera can .. point the remote at the digital camera and you should see the LED flashing in the cameras viewer when a button on the remote is pushed ...
Posted on Nov 05, 2009
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
Turn off while watching
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 07, 2014 | Dynex 55 Class LCD 1080p 120Hz HDTV
No video or audio input through composite video or HDMI 1 on an Emerson 32 inch LCD HDTV
Check and replace its main power regulator board. It is not working. Might be faulty.
Jan 29, 2013 | Emerson LC320EMX 32 in. LCD HDTV
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
Please see my grundig TV question It switches on automatically at 0300 every morning.
Please reset the TIMER- the DELAY - ON/ morning timer is set to active condition and so since the TV also is in the standy by mode it will switch on as set on the memory. You can remove the power for an hour to reset the memory.
Oct 31, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Good morning ! son threw toy @ tv now a bucnh of lines on sceen
you will need a new lcd panel . a new panel is probably going to cost you as much as you paid for a new tv. you could try looking for a used one
Jun 07, 2009 | LG 37LC7D 37 in. LCD HDTV
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
TV will not come on by using the remote control
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Nov 17, 2008 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
