I have dual monitors set up on my computer with the left monitor (22 in) identified as monitor 2 (primary). The right monitor (19 in) is identified as monitor 1. The reason I have this setup is because the driver for the 22 in monitor is on number 2. Every time I turn the computer off and back on, the positions change with monitor 1 on the left and monitor 2 on the right. How do I change the number assignment of the monitor drivers? Or how do I correct this?
  • 1 more comment
  • Manny Aquino Jul 28, 2010
    Windows Vista 64-bit
    Windows Vista 4-bit
    yes. i mean iclicked "Apply" and then "OK".
    President:
  • 567 Answers
Hi there i need to know what operating system are your computer using ?
Posted on Jul 28, 2010
  • 1 more comment
  • Hilton Bristol Jul 28, 2010
    Hi after you set monitor 2 as primary monitor did you apply the setting and save it?
    Okay i think i see the solution to the problem you are having,you have to set monitor 1 as the primary monitor,thats the only way the problem will solve .
    With computers number 1 always go as primary
Can I use the AMD Radeon HD 7540D Integrated Graphics with 1 HDMI and 1 VGA to use dual monitors?
Hi Veronica,
Absolutely you can.
After you get the monitors hooked up and powered on, RIGHT click on the desktop...anywhere. Select "Screen Resolution" Once the display settings pop up, select "Detect". After you select that, you should have 2 monitors show up..one should say 1 and other should say 2. To Identify which one is which, click the "Identify" button and you should see a #1 and 2 on your monitor screens.
If you go down to where it says "Multiple Displays", that is where you can set them up to be extended, or duplicated.....Extended just means that one of the displays is going to be primary and the other display is going to be an extension of that. Duplicate is just that...both screens show the same thing.
Hope this helps:)
Thanks
Gary
Oct 28, 2013 | Computers & Internet
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Aug 02, 2012 | E-Machines eMachines Desktop PC
Dual screen wont work
Kevin,
1) You cannot plug a monitor into the VGA connector, on the back of the desktop computer, AND plug a second monitor into a DVI connector, on the back of a desktop computer.
In otherwords you can only plug ONE monitor into the motherboard.
[ The I/O area on the back of the desktop computer, is the Input/Output area. This rectangular area has connections for Input devices, and Output devices.
Examples such as a Mouse, Keyboard, (INPUT), VGA devices, (VGA monitor - Output), USB devices, audio devices, (Speakers - Output. Microphone is an Input device), and so on.
The I/O area has a rectangular metal shield. (Thin metal plate)
Connecting a device in the I/O area, is connecting it directly to the motherboard.
Example of a VGA connector, and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(There are several variations of DVI connectors.
Scroll down ]
To use dual monitors you need a graphics card also.
Graphics card with a VGA connector, or DVI connector. (Or both)
Monitor with VGA cable, plugs into the I/O area on the back of the desktop computer. (Plugs into the motherboard's graphic chipset)
The second monitor plugs into the graphics card's DVI connector, or VGA connector.
[ Just an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1416091&CatId=3669
On the image of the graphics card on the left;
Go under it to the subheading - + 11 larger images and views.
There are 7 views shown. One is the carton the graphics card comes in. (View 2 from the left)
Going from the left side, count over to the 5th view. Left-click on the 5th view. Shows you the 'business end' of the graphics card.
Starting at the left side it is the HDMI connector, then VGA connector, then DVI connector.
Note*
YES, you can plug a VGA monitor, AND a DVI monitor, into this type of graphics card, and have Dual monitors ]
FIRST:
Computer on, Windows running; Put the Installation disk (CD) in the optical drive's tray. (CD/DVD drive)
Load ALL software.
Drivers, and 'Control Panel'.
Graphics card software loaded, close all windows, go back to your desktop screen. Turn the computer off normally.
Unplug the computer from power. Open the computer case.
FOLLOW Anti-Static Precautions.
(Don't know Anti-Static Precautions? Post back in a Comment)
Physically install the graphics card. Close the computer case.
Plug the VGA cable of the Primary monitor, into the VGA connector in the I/O area, on the back of the desktop computer.
Now plug the DVI cable of the Secondary monitor, into the DVI connector on the graphics card.
(The main monitor you use is the Primary monitor. The second monitor you are going to add, is the Secondary monitor )
Plug the computer into power. Both monitors plugged into power, turn them BOTH on.
Turn the computer on.
When Windows loads you will see a display on the Primary monitor.
Your desktop screen.
Now Right-click on an empty area of your desktop screen.
In the list at the bottom, Left-click on - Properties.
In the Display Properties window that comes up, left-click on the -
Settings tab.
You will see two rectangular icons. 1 and 2.
1 is the Primary monitor. 2 is the Secondary monitor.
Left-click on the Secondary monitor icon.
Go down towards the bottom/middle on the left.
Left-click in the empty square to the left of -
Extend my Windows desktop onto this monitor
Go down to the bottom Right. Left-click on Apply.
Go down to the bottom Left. Left-click on OK.
Your desktop screen will now be on the secondary monitor.
When you open your internet browser, (Yahoo, or Google, or MSN, or Mozilla Firefox, etc), you have to DRAG the screen onto the secondary monitor.
(Let's use Yahoo for an example. Yahoo will be on your Primary monitor.
You need to drag Yahoo onto the Secondary monitor)
Which direction you drag, is up to which direction the two monitors are sitting, on your computer desk.
The way the monitors are sitting in Display Properties; the Primary monitor is on the Left. ( 1 )
The Secondary monitor ( 2 ) is on the Right.
This is the way the two monitors should sit on your computer desk.
(There is a way to switch them around, however)
On your Primary monitor, (Still using Yahoo as an example), go to the RIGHT side. See the blue frame going around the screen?
When you bring the mouse cursor ON the blue frame, it turns into a Double-Sided arrow.
It is difficult at first to keep the cursor as a double-sided arrow.
Move too far to the right, it turns into the usual pointed cursor.
Move too far to the left, and it turns into the usual pointed cursor.
have to keep it on the blue frame.
WHILE the mouse cursor is a Double-Sided arrow, left-click, and hold the left mouse button down. Now drag the screen to the Right.
(Move your mouse to the right)
Keep dragging until the Yahoo browser is on both monitors.
Different size monitors? The display will not be the same size, on both monitors.
[ I use an HP 2009m, 20-inch widescreen monitor, as a Primary monitor, and an RCA EN-V, 26 inch HDTV, as a Secondary monitor.
I have my desktop on the Primary monitor, and FixYa, (Firefox browser), on the Secondary monitor, right now ]
If this is not your problem please state in a Comment.
Also state additional questions in a Comment.
Regards,
joecoolvette
May 10, 2012 | Computers & Internet
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Nov 24, 2010 | Computers & Internet
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
How can we connect two moniters to one cpu
To have and use 2 monitors at the same time, you need a video card with a dual VGA outputs.
To use 1 monitor at the time you can buy a VGA switcher, to switch between the 2 monitors.
Best of Luck
Sabre
Feb 18, 2010 | ViewSonic Computers & Internet
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dual monitor, Intel 82915G, ATI Rage 128 card, FC6
the ati chip is not so good dual monitor so please use nvidia for dual monitoring
Jan 09, 2009 | HP ATI FireGL4 (128 MB) Graphic Card
Dual Monitor Problem
Go to Control Panel, select Display, select Settings - change the drop-down to select which display is Primary?
Dec 28, 2008 | Computers & Internet
Dual monitor setup
Assuming you are using Windows Vista:
All you have to do is connect your laptop to a monitor via a VGA port (located on either the side or at the back of your laptop - it's the port with about 15 holes).
Once connected , you will need to configure how your 2nd monitor will function - as an extended or duplicate monitor. To set this you will need to go to Display Settings > and select your option.
Sep 28, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
