Question about Whirlpool Dryers
I am trying to get the blower wheel off the motor shaft. What is the best way to do that? Model LER7648PQ0 dryer. I know that it is a left handed thread.
  • Whirlpool Master
  • 12,061 Answers
Https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa?OpenDocument
Please find above your service manual above, this will help you troubleshoot and hopefully repair.
To get this off we use a gear puller, or a vice and a drift. sometimes there is a key to remove, or a grub screw, but often it is just a friction fit.
Spray with WD40, onto the assembly and let sit for a while, this too will help.
Use the manual diagrams to help you.
http://www.ehow.com/how_5522847_remove-dryer-blower-wheel.html
Above is a how to.... and below.
www.ehow.com › ... › Home AppliancesWasher & Dryers -
Posted on Jul 28, 2010
Whirlpool ultimate care ii dryer, only works when continuosly pressed the start button. What can be the problem. whirlpool ultimate care ii dryer model gew9878lw0
More likely than not either the start/run switch on your motor wen't bad, or the motor windings itself. Either way you need to replace the motor #279827 around $100 on up.
Not tough to get to if you know how to gain access to the cabinet, just remember that the blower wheel and motor threads going into the blower wheel are LEFT hand thread,
have fun, and best of luck,
ttfn
Feb 04, 2010 | Whirlpool Dryers
How do i take the fan off
Good day,
You need a good wrench that will fit on the nylon shaft of the blower. A second wrench is needed to fit on the flat of the pulley on the front of the motor.
It's best, if the motor is still mounted in place.
The threads on the blower wheel are LEFT HANDED, which means you turn the wrench on the front of the motor clockwise to loosen it.
Once again, the wrench used on the blower wheel must be a good fit. It is best to just let it rotate, until it rests on the bearing support shaft. Apply pressure (usually a lot). If it breaks loose, continue to turn it until it falls back into the rear cavity.
If it rounds off, don't feel bad. About half will come off, the rest will not. You'll need a long screw driver or chisel, to break it off.
Thank you for using FixYa
Jan 13, 2010 | Kenmore 62602 Electric Dryer
The blower fan is lose how do you tighten it up . Whirlpool Duet Dryer
Use a 3/4' wrench on the blower wheel and a 7/16 wrench on the front shaft of the motor. The threads on the rear shaft are left hand threads so make sure you turn the shaft in the proper direction.check the wheel for cracks,usually if they are loose they're damaged,
Dec 18, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Maytag LDE8600ADM Electric Dryer is making a loud knocking sound when it startes up and continues slightly quieter, but none the less knocking, while running and then the same loud knocking as at the...
Hi, Start the dryer and listen down in the lower front corner for the noise. This sounds to me like it could be the blower wheel loose on the front motor shaft.
Remove the 2 screws in the front panel and then remove the 4 screws holding the front bulkhead to the cabinet. You will be able to see the blower wheel and try to spin it by hand. If the blower spins free on the shaft, it will need replaced.
I hope this is helpfull to you. Please let me know if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Dryers
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Blower wheel loose on shaft of motor on maytag dryer
GO TO www.repairclinic.com and enter the model number look for your blower wheel item 1245880 it looks as if there is a flat side on it. this may help ya Good luck
Apr 09, 2009 | Dryers
LGR6611LQ0
you can but now you have to turn the motor shaft at the belt end..i believe you can put your adjustable behind the plastic square blower wheel shaft..on the motor shaft and try turning with your hand its hard to turn because the drum when turning turns the oppsite way,,im,,here onthejob..use gloves
Jan 10, 2009 | Whirlpool LGR6611L Gas Dryer
Replacing roper motor help
i know its tricky.i use a vise grips on the motor pully,then use cresent wrench on blower .it is a left handed thread and that makes it trickier.look at your new motor to get an idea the way you want to turn it.you can do it God bless,tom
Jan 02, 2009 | Roper REX3614KW Electric Dryer
Blower moter fan
Before attempting to remove blower, run the motor and note the direction of rotation. The blower wheel can be very difficult to remove. It is screwed on to the motor shaft opposite to the motor rotation such that every time the motor starts, the blower wheel gets tighter. The best way to remove, is to put an adjustable wrench on the blower wheel (from the motor side) and using another wrench or locking pliers on the side of the motor shaft where the belt goes. Rotate the motor shaft where the belt goes, in the opposite direction of normal rotation while holding the wrench on the blower wheel. It will be VERY TIGHT. If unsuccessful, the only alternative is to strike the blower wheel REALLY hard and break it off. GOOD LUCK!
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Whirlpool LER5636P Electric Dryer
I am trying to remove and replace the motor on a whirlpool dryer. i bought the unit new in 1994. i can't seem to get the motor shaft loose. i am trying to turn the shaft in the clockwise direction and with...
check the end threads of the new motor are the not left hand threaded, if so you are tighhtning turn the oppisite direction
btw you may have to replace the blower if it cracked the blower when the plasitc came off might have to use vise grips to ge it off
Apr 26, 2008 | Dryers
Dryers Logo
114 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
