Question about Gateway MX7118 Notebook
How to write spanish characters?
How to write spanish characters with this laptop
i read somewhere that i have to click num lock and then alt+164( for n tilde, for example)
but i don't see any num lock here
does it have to do something with fn key?
  • bogdanno Nov 07, 2008
    i solved the problem in the usual way
    i dont need help no more
    thanks
    Scholar:
  • 149 Answers
Yes some portables you have to press fn key look for the key that says alt in blue color and use the numbers on keyboard it's in blue too relase and wala spanish caracters
alt 130 é
alt 160 á
alt 161 í
alt 162 ó
alt 163 ú
alt 164 ñ
alt 165 ñ
alt 168 ¿
alt 129 ü
Posted on Apr 23, 2008
  • Alexander  Figueroa
    Alexander Figueroa Nov 08, 2008
    also you can set your keyboard for united states international and when you press the right alt + the letter it comes out for capitals just press the alt shift and letter desired
Cick on start, go to all programs, go to accessories, then to system tools and go to character map .you can set you keyboad.
"BINGO"
Posted on Aug 27, 2010
Need to be bette explained, confusing. Couldn't make it work in my laptop
Posted on Oct 09, 2008
I need the capital letters. im doing a project for my spanish III class and i need the shortcut for a capital "o" with an accent
=( can you help?
Posted on May 21, 2008
Im doing a project also and I have the same problem!? =(
Posted on Nov 06, 2008
How to type spanish accents
Try:
http://www.spanishdict.com/answers/100808/how-to-type-spanish-letters-and-accents-#.VCffvecmYhM
Apr 08, 2014 | Apple Computers & Internet
How to change numeric to words
If you mean special characters like for the yen sign ¥ or the Spanish ?, then the way to do this is by holding the ALT key followed by a number sequence.
You might be talking about the special or Fn keys. Sometimes people accidentally hit this key on the laptop and change their letters to words. Getting rid of the num lock on this depends on the model of the laptop, but it's usually turned off by using the Fn key + an icon that symbolizes num lock on your laptop, which you'd have to find out by going through your laptop's manual.
You might also mean concerting ascii numbers into their counterpart. In which case, there's a way to do this using the python programming language using the chr() function. Where you put the number in between the parenthesis to find out what the corresponding number is.
for example:
chr(97) would yield an 'a'
That's about all the possibilities I could guess your question meant. Hope at least one of them was the right one.
Mar 11, 2011 | Computers & Internet
Hi, I bought a HP Pavilion dm4 two months ago and it seems that it doesn't contain a number lock key. I was wondering if there is a way to insert special characters without going to symbols and copy...
If you were to click on start then All programmes. Select Accessories and then character map.
Select a font and then the code you require.
I find since WinXP Alt0189 no longer works properly and use the character map instead.
Hope that helps.
Feb 28, 2011 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Sir how to apply n-ye letter in my acer. everytime i use my middle name munoz. it should be n-ye in the n of munoz. pls hlep me how. because in cpu i can use alt 165 and alt 164. tnx.
You have to use special function ñ = ALT+(NumPad)164 ñ=ALT+(NumPad)165
I hope it helped you. Rate for this information will greatly be appreciated. Thank you for choosing FixYa!
Jan 31, 2011 | Acer Aspire 5050 5430 Laptop
My Compaq laptop keyboard seems to be stuck in ALT mode. All the keys which have an alternate character in the upper right corner, will only type those characters. For example, the "m" key will only type...
Never ran into this problem myself but a friend of mine has. He said what fixed his what holding Fn + Num Lock and it remedied his problem.
Unless your key is stuck/broken you can also try a can of air and try to blow it out and or pull the key and make sure its not stuck down.
But deff try the holding Fn + Num Lock method first.
Jul 18, 2010 | Compaq Presario 700 470024-192 Notebook
Dell D600 Latitude laptop. Spanish characters when using ALT key and a # do not work. Suggestion?
Go to Programs/Accessories/System Tools and click on Character Map. You will need to do a cut and paste of the character from there. Laptop keypads don't support the Alt# sequence for inserting characters like a conventional keyboard does.
Jan 07, 2010 | Dell Computers & Internet
I don't know how to write spanish caracter in my laptop it is an acer5610
ñññññññññññññññññññññññññññ :P
U need to change ur keyboard configuration, go to: Control Panel Clock, Language and Region Change keyboards or other input methods Click at Change Keyboards Add an spanish language (idk which one u will prefer, i use mexican) Then change ur default keyboard to it.
Ahora eso es si quieres cambiar tu idioma principal a español, if u dont and just need a character, use the ASCII code:
Press and hold ALT + 164 for ñ and 165 for ñ
Nov 03, 2009 | Acer Aspire 5610-4648 Notebook
How do i make a character that looks like a 7 but vertical portion is straight
The answer is ALT + 191
To obtain an ALT Character:
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear
Found here... http://www.tedmontgomery.com/tutorial/altchrc.html
You will find all the special characters there.
Thanks,
John C.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
I need spanish
The @ is at Alt-Gr + Q
now to change it to spanish you will have to reinstall a spanish operating system. If its a new laptop, with a legal operating system, then i would try to trade it with the manufacturer.
Dec 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Working with alt spanish codes
Alt Codes for typing Spanish characters:Here are the codes for Spanish Accents: Capitals á ALT+0193 é ALT+0201 í ALT+0205 ó ALT+0211 ú ALT+0218 ñ ALT+0209 ü ALT+0220
Lowercase á ALT+0225 é ALT+0233 í ALT+0237 ó ALT+0243 ú ALT+0250 ñ ALT+0241 ü ALT+0252 Punctuation ¿ ALT+0191 ¡ ALT+0161 « ALT+0171 (Left Angle Quote) » ALT+0187 (Right Angle Quote) € ALT+0128 Buenas Suerte,
Jose Diaz
Please rate this.
Nov 21, 2008 | Gateway MX7118 Notebook
Open Questions:
Gateway MX7118 Notebook Logo
2,311 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
