Question about Rockford Fosgate T10001BD- Car Audio 500watts Mono Power Amplifier Car Audio Amplifier
Recently, my Rockford amp started coming on and going off randomly. Have never had any problems with this amp, and have had 2 car audio professional "opinions" that the amp has gone bad. After playing around w/ it, the major problem seems to be centered around the fuse section of the amp. For instance, if I touch the screw that connects the fuse to the amp or hold something against it ...the amp will turn on. If I continue to hold it, the amp will continue to play. If I let go, the amp will play for a couple more secs., then will turn off. Is this something that can be fixed or will I really need a new amp? (Also had a couple of my buddies look @ it, and they seemed to think if I replaced something just in this region that I should be fine). However, not one of them has told me that the fuse is blown. So I'm thinking there is something else going on w/ the fuse section! Any help is appreciated! Thanks!
    Top Expert:
  • Rockford Fos... Master
  • 39,444 Answers
A defect in the fuseholder or connections. A complete replacement of the fuseholder may be necessary.
Posted on Mar 11, 2017
2 Suggested Answers
  • 323 Answers
SOURCE: Recently, my Rockford amp started coming on and
You could always unscrew the screw that holds your fuses in place and screw it back in firmly and see if that works.
It is possible the fuses are arching though. You can try unhooking the amp from the battery and turning your gains down. Then remove the fuses. Replace the fuses with new ones and hook everything back up and see if the amp runs more efficiently.
Bad ground can cause the amp not to come on too.
I always strip off the paint from the chassis of the vehicle before putting in a ground wire. Paint is not a conductor.
Posted on Jul 28, 2010
Rockford R-1000-1D going into protect. Hooked up to two P3D212's. Wired at 2 Ohms. Not to mention checking and double checking and triple checking all the wiring to and from the amp. What could be...
  • First of all this amp is not "bridgeable" per the data sheet and Rockford Fosgate's. Short story your overloading the amp. You may be able to physically run it "bridged" but it is going to kill the amp. No doubt the set up will pound... itself right into the amplifier graveyard. The amp does not have to get hot to go into protect mode, it only needs to sense a malfunction as well.
  • Something else to. The speakers are rated at 2 Ohms as well as the amp (2 Ohms) That means the least Ohms you can but to the amp is 2 Ohms. When you bridges them 2 speakers you drop it down to 1 Ohm. Unsatisfactory for the Amp to function properly.
Tony
Jun 01, 2011 | Rockford Fosgate R10001D Car Amp
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Recently, my Rockford amp started coming on and going off randomly. Have never had any problems with this amp, and have had 2 car audio professional "opinions" that the amp has gone bad. After playing...
Jul 28, 2010 | Rockford Fosgate T10001BD- Car Audio...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Amplifier not working
If the speakers are being driven in or out and remain there when the amp is on, the amplifier likely has shorted output transistors. These are not easily replaced in the Rockford amplifiers that use the MEHSA insulators. Unless you're interested in learning to do this type of work, it should be sent to Rockford for repair.
Sep 09, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
41 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
