My Rinnai convector 516 heater filter light flashes constantly and after a while I can't feel the heat coming out of it. Is ther something simple I can do. I have washed the pull out filter screens at the back and what does this actually mean
  • kberri Jul 29, 2010
    Yes the filter light is flashing and just today all the lights have started flashing arghhhh!
    Yes the filter light is flashing and just today the all the lights are flashing!!!!arrgh!!
    Novelist:
  • 120 Answers
Just to explain each flashing light is telling us something. These units display error codes to us by which light flashes. The only fault that makes all lights flash is if there was a power failure whilst the unit was operating. I sort of doubt this one being the cause unles the actual power lead to the unit or the electrical plug itself is dodgy. I need you to be certain of which lights are flashing, the ones between the high and low marks are the important ones, each one means a different thing. My gut feeling is this is not a simple problem and will require a good technician to physically sort it out. I always recommend getting these serviced and cleaned every year anyway. Even if I could tell you whats wrong, it's very unlikely that it would be a simple fix for a DIY person.
Posted on Jul 30, 2010
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
Dear Sir after bearing 90156704 left hand bearing for convection fan for gas heater Rinnai Convector 516 TR can you please help tell where I can find it to buy it Thank you Joe
If you reside in Australia, you can call Rinnai Customer Support: National Mon - Fri 8.00am to 5.30pm EST 1300 555 545
I hope this helps you and thanks for choosing FixYa. Cheers!
Aug 25, 2011 | Heating & Cooling
Our Rinnai convector unflued room heater won't start. Lights just flash heat never comes on.
According the the Owner's Manual for your Rinnai Convector Heater, there are 8 things, than can cause what you described. Two of which can be discounted, unless you just had the heater installed.
I have provided a link to the Owner's Manual, that you can download and print for future reference. Please pay close attention to Page # 6 -Pre-Service Check List and Fault Finding. Each problem listed has a troubleshooting solution.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Granada252/portable_radiant_convectors.pdf
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Cheers!
Jun 17, 2011 | Heating & Cooling
OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Sep 06, 2010 | Heating & Cooling
How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Nov 09, 2009 | Heating & Cooling
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
504 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
