Question about Dewalt DC925 Cordless Drill
When putting a screw tip on the gun it locks up?
  • 43,501 Answers
Try and work some WD-40 into the chuck to get it to free up...
heatman101
Posted on Aug 27, 2010
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
How do i change the tip on my screwgun?
put the gun in reverse (the setting to remove a screw), while pressing the trigger with one hand, hold the gun with the other hand on the part that spins, but not the tip itself. hold it firmly, and as it attempts to spin, the tip holder will open wider and release the bit
Jan 23, 2013 | Electrical Supplies
Hi, my hitachi drywall gun runs good but the bit dosent spin, it dont screw. any idea. thanks
drywall guns wont spin until you put pressure on the tip, load a screw and put it to the wall (or whatever) add pressure and pull the trigger
May 08, 2011 | Hitachi W6V4 4500 Rpm DryWall Screw Driver
Tip screws for model 8200 are worn out, What is the screw size?
The tip screws are a drilled bolt for this unit. There isn't room to tap the barrel holes out further if the threads are bad. You used to be able to buy tips that were pre-loaded with the proper clamp bolts. Good luck!
Aug 05, 2010 | Weller 8200 Soldering Gun
Need to know how to operate milwaukee screw gun?
I hope you're talking screw gun and not drill/driver. Screw gun used specifically to set screws in drywall. Make sure you have proper tip in gun (usually #2 phillips). There should be a rotating collar on the gun to control screw depth. The screw should only "dimple" the drywall. It should not tear the paper but should be below the plane of the drywall. To check depth run a putty knife over the screw heads. If you hear it hit, screws need to go a bit deeper. To work quickly; lock the trigger on and place the screw on the gun. Apply steady pressure and let the screw walk into the board until gun breaks free. Takes a bit of practice but pretty soon you'll be flying.
Mar 02, 2010 | Milwaukee Tool Drills
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
Jan 03, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
The light comes on. It does not heat up. The gun worked a day ago, what's up?
The tip is probably dirty. Loosen up the screws on the side and pull the tip out. Clean them off by scraping them with a knife or with sandpaper. Put it back in and tighten the screws. It should work then. Sometimes it's just that the screws are loose.
Nov 29, 2009 | Weller 8200 Soldering Gun
Weller D550 fried brand new tip
are you sure you bought the H.D. tip this is the big gun
Jul 12, 2009 | RTO Weller D550 Soldering Gun
Dewalt DC925 Cordless Drill Logo
44 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
