Question about Sanyo DS31590 31" TV
Ps2 hookup to a sanyo 42in. flatscreen 1080p
Sound is in surround sound through stereo. but picture is in black and white. Why not in color?
  • 54 Answers
Need to resolder the parts inside they call it CRYSTAL to make the color cameback. It happen mosthly bcoz of the old of the tv.
Posted on Apr 24, 2008
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
How do i set up a ps2 to a tv that only has a yellow and white input
It's called a "composite" adapter cable for PS2. The yellow RCA connector is composite video. The white RCA connector is left-audio (usually there's white and red for stereo - left/right)
There should have been a cable that came with your console, but in case you bought it used, here's a picture of what it looks like.
Also, you can buy one aftermarket:
http://www.amazon.com/MONSTER-CABLE-Hookup-PlayStation-PLG200/dp/B0000524PE
Look around, I wouldn't pay more that $15 for it.
Oct 03, 2009 | Sony PlayStation 2 (PS2) Console
How do i hook up ps 2 to surround sound system
PS 2 only supports stereo out of the box so you would need to run it through a surround sound reciever in order to obtain surround sound. You'd plug the red & white into an audio in jack on the back of the reciever. Hope this helps.
Sep 21, 2009 | Sony PlayStation 2 (PS2) Console
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Ps2 hookup to lcd tv
If your sanyo has a video input (yellow) available, and audio inputs available (white and red) then you just need to connect them. Then you need to select the proper input on the TV set. These may be on the back, side, or front of the TV.
Good Luck, and let me know how it worked out!
Jan 01, 2008 | Sony PlayStation 2 Slimline Console
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
Sanyo DS31590 31" TV Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
