Question about Canon PowerShot A410 Digital Camera
I do a camera drops the ground. Thereafter It's show error E18
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
I have a PowerShot S2 IS Icannot take a picture screen show E18.
E18 is the standard Canon lens error. The lens gets stuck when extending. If you did not drop it and there are no signs of damage you can check with Canon and try to get the camera repaired under warranty.
If it is not covered here are a few methods to try on your own, at your own risk.
http://www.e18error.com/repair.html
Good Luck,
-WN
Dec 28, 2009 | Canon Cameras
Have Canon PowerShot A80. New batteries, turn on and it automatically turns off with a buzzing/clicking noise... Window shows error E18
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try:
Nov 14, 2009 | Canon PowerShot A80 Digital Camera
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Aug 21, 2009 | Canon Cameras
Canon camara was dropped and now it reads e18. Camara still shows pictures on the display screen
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 28, 2009 | Canon Cameras
My camera is showing E18.I can't take photos. What
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | Canon PowerShot A85 Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
I have a cannon s2 15 and the lens wont go back into the camera and a error of E18 shows on the view finder
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 14, 2009 | Canon PowerShot A75 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
LENS STUCK IN EXTENDED POSTION
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A410 Digital Camera Logo
13 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
