Question about Apple iPod nano
I bought a used ipod touch and now I can't get into the ipod without the code---what do I do
I bought a used IPOD Touch, everything was wiped clean, now all I can see is the apple, and cant get into it
Posted on Sep 18, 2010
What is the code to unlock an ipod touch 1st generation
Please contact me at: service@gps.pol.pl
Dec 24, 2011 | Apple iPod touch
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
I have an ipod touch 8gb that is disabled. it belongs to my daughters friend and i am trying to enable it. she lost the password
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod. Then you should be able to restore the iPod without the code.
Nov 27, 2011 | Apple iPod touch
My ipod touch is locked and i forgot the passcode
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and let you restore it without the code.
Nov 26, 2011 | Apple iPod touch
I forgot my pass code. how can i reset my ipod touch.-
If your iPod touch is password locked, the only way to get past it is to force the unit into restore mode by doing the following:
1. Plug the iPod touch in to your computer.
2. Hold the sleep/wake button and the menu button down at the same time. Keep them both pressed until you see the 'restore' screen (an iPod cable and an iTunes disc symbol) on the iPod touch. Release the buttons.
3. iTunes should now display the iPod touch, along with a message that the iPod touch is in recovery mode. Click the RESTORE button in iTunes to restore the iPod touch.
Please note that doing this will erase the contents of the iPod touch -- that's how the system is designed to work: a passcode lock is meant to protect the data on the iPod.
^This works too, but if you have important data on it you can hold down the on/off button and the square button until it goes off , and then press the square button to get it to turn back on. I had to do it too :(
dont forget to rate me....
good luck....
Apr 19, 2010 | Apple iPod touch
Had Ipod touch but lost it and now have used one
If you are on Windows:
Download and install SharePod
If you are on OS X:
Download and install the Senuti free trial
Sep 26, 2009 | Apple iPod touch
Need a cose to unlock my ipod touch
Obviously you don't know the code. Plug it into your computer with iTunes open (preferably the computer where you first set up your ipod), and it should unlock itself after the sync, or be able to be used without the passcode.
Otherwise, you're going to have to restore it. Full details on that at http://support.apple.com/kb/HT1339?viewlocale=en_US
Sep 18, 2009 | Apple iPod touch
Four digits code on my ipod cant figure it down since i didnt put any help please...
Sadly, the ONLY way to unlock any iPod without the password is to restore it using iTunes. Below I have posted a step by step on restoring your dads new iPod touch. I hope that is easy to follow and very informative. Please remember to rate experts here (good or bad) we need the feed back. :)
Last Modified: February 16, 2009 Article: HT1414
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All of the iPod touch settings are restored to their factory condition.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
May 06, 2009 | Apple iPod touch
How do you unlock a used ipod touch?
Hi, fortunately, this is an easy solution. You will lose all the content currently on the iPod.
Follow the instructions as outlined here:
http://support.apple.com/kb/HT1808
Apr 17, 2009 | Apple iPod touch
I pod touch
yeah it say try after how many thousand minutes right?put the ipod first in recovery mode.then restore it using the itunes,in that way the password will be removed but the dis advantage is it will format the ipod erasing everything inside.fixya
Dec 22, 2008 | Apple iPod touch
Apple iPod nano Logo
88 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
