Question about White Rodgers 0754-1 Electric Water Heater Control
My thermostat is showing FLTR and STRG on it. the setting temperature blinks for a while. the snow flake symbol shows up by I am not getting any cold air.
I have a Richmond 50 gallon on core water heater electric only have about five minutes for the hot water from do you were at the shows on the display bottom tank is at 58° how do you adjust the bottom part...
It appears that the water heater has 2 elements but on 1 thermostat, I would hope that there is an upper and lower thermostat . If water heater has just been installed the cold water feed is hooked to the hot water discharge, Cold water to cold hot to hat. They are marked on top of unit..Or the unit was powered up before tank was fully purged. If there is only 1 thermostat Shut power down and using a DMM check resistance on upper heating element and compare to lower. If the element is damaged it will show a high resistance. You can buy replacement elements, at box stores.
https://hw.menardc.com/main/items/media/RHEEM001/Install_Instruct/StandardElec_UC.pdf
Mar 14, 2018 | Water Water Heaters
What is snowflake symbol
shows that the setting [temperature] is set to come on when a temperature inside gets below 2 degrees or zero
Apr 10, 2015 | Lux PSD111 Digital Non-Programmable Single...
Control on whirlpool EEZ8OHD055V Blinks twice, no hot water
1) Call Whirlpool. 1-877-817-6750
Have them send 2 new thermistors (temperature sensors located above each element), and then install according to the instructions they give you.
2) Sounds like you have the American brand older energy-smart electric water heater with grey control box on top
Copy following link to exactly identify product and resources
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html#energy-old
3) Two flashes is 'high water temperature shut down.
Buy cheap multimeter from hardware store. Install battery. Set to read ohm, the upside down horseshoe symbol.
Use multimeter set to read ohms, and test thermistors
Copy following link for general service manual showing error #2 and thermistor resistance chart on page 10
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2012 | Water Heaters
I have a Rheem 41VRP50N water heater. The water I am getting is luke warm on a good day. The burner fires up when I turn the thermostat to the highest temperature only. I drained the unit and flushed...
This condition can be caused by 4 different problems, or combination of these problems.
Good indicator would be to check temperature of water inside tank.
Put bucket under TP overflow tube and release water into bucket, then use cooking thermometer to gauge temperature. Stand back from scalding water that can shoot out of overflow.
If tank temperature is 120-130:
1) Crossover is suspect:
http://waterheatertimer.org/Crossover.html
If tank temperature is low:
2) Bad gas control valve thermostat is suspect.
I believe Rheem 41VRP50N has Honeywell or White Rodgers electronic gas control valve.
Open following link to identify gas control thermostat and see typical error codes.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Honeywell
Replacement gas valve can be purchased from Rheem.
3) Combustion parts and tubes need cleaning, and bleed gas line for air and water contaminants.
4) Water heater has sediment build-up coating burner transfer surface and covering thermostat.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Year of manufacture for Rheem water heater is 2nd two digits of serial number, so XX03.. would be 2003.
Add a comment and say what you did to solve problem.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Rheem Water Heaters
Change temperature setting
You posted under Rheem water heater but don't give type of heater or type of fuel.
Open following link for typical water heaters and many different kinds of thermostat controls:
For more detailed information, add a comment with information from the label on side of unit.
Label will say if water heater is tank-type or solar-assisted, tankless, and if water heater is gas or electric.
Product manual will also show thermostat information.
Add a comment and I might have link to your manual so each of us can read about product.
Manuals are critical tool for getting unit to work correctly over time, and important for homeowner showing needed maintenance and advisories for each model.
Upvote the help.
May 30, 2011 | Rheem Water Heaters
What to do if water doesn't get hot even though I have increased the thermostat settings... the heater isn't even4 months old and it has done this from day one
You have electric water heater.
Electric water heaters are fully repairable by homeowner.
Reliance is AO Smith company
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
http://www.reliancewaterheaters.com/prod/elec.html
Age of Reliance water heater is shown on serial number located on side of tank: first digit is letter. Next two digits are numbers: for example C06 means 2006.
Serial number also shows model number & wattage of elements in case you need new element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or element.
Narrow down the suspects:
Water heater is 240Volts since you have more than 1 thermostat.
Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Dec 13, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
Oct 08, 2010 | Water Heaters
EA error msg on Bosh tankless unit
How I fixed it was got rid of it...support help never called back..and to get parts for it was looking into the new year can't go without a shower that long...can we now?
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
White Rodgers 0754-1 Electric Water Heater Control Logo
96 people viewed this question
Top White Rodgers Water Heaters Experts
Steve
Gene Haynes
Are you a White Rodgers Water Heater Expert? Answer questions, earn points and help others
