Question about Fisher Paykel EcoSmart GWL15
An alarm sounds when it gets to the rinse cycle and it will not proceed any farther. Jeff
  • pjdkinne Jul 28, 2010
    Hi Guru,
    Model #GWL11
    Serial #BIN516118
    There are 8 lights - 5 washer lights; 2 rinse; 1 spin.
    Lights 3(green), 6(orange), 8(red) are on and there is a continuous high pitched beeping sound.
    Also, when the washer fills with water there is often a screeching sound.(not always)
    Thanks
  • pjdkinne Jul 30, 2010
    Dear Guru,
    Thanks for your additional diagnosis. Yes it is the 3rd, 6th, & 8th lights. The washer does drain the water from the machine. There is a pump with a black fan just where you said it was.
    The machine would drain the water after the wash cycle and then sit there and not go into the rinse cycle.
    Thanks for more help.
    Jeff
  • Fisher Master
  • 713 Answers
Hi Jeff just read your posting.When the beeping starts a series of lights will start to flash .These lights will be in a row of 8 lights.Starting from the left to right which ones are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc---?If you have the model with an LCD display then the error code will show as it beeps.Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 28, 2010
  • 6 more comments
  • luisa_sgro Jul 29, 2010
    Hi Jeff just read your 2nd posting and as I understand the information from it, the 3rd, 6th, and 8th light is lit when the machine beeps.Is this correct?If it is then your machine has Error Code 37,which is called Pump Block Error.This means that the computer has not detected the water draining from the machine.Does your machine drain the water?If it does drain the water then the problem is either your Pressure switch tube or Main controller.If it does not drain the water then it could be a jammed pump.Please look underneath the machine to the front right and you should see a red or black fan.This is your pump.Please reply with additional information on the questions and also to confirm if you have the style of pump with a fan attached.Looking forward to your reply.
  • luisa_sgro Aug 01, 2010
    Hi Jeff.Now just a couple of questions again.Is your machine draining into the laundry sink or some place else?If it is draining into the laundry sink how fast is it draining?The reason I am asking these questions is that error 37 also appears if your water is draining, but drains slowly.Please check the rate in which your machine is draining,by watching the water come out of the drain hose.The other reason why your machine could be faulty is the pressure switch tube is blocked or partially blocked.Now to test this fault make sure there is no water in your machine and then turn it off at the wall.Now remove the top cover by undoing the 2 screws at the back of the top panel.Pull the top panel slowly away from the machine as it has the display module wiring attached to it.Rest the top panel on the lid with the wires still attached and you will see your motor controller.I think by memory it will be brown in color.Now on this controller you will see a clear tube attached to it.This is the pressure switch tube.Remove the tube and blow down it to make sure it is not blocked and then refit.Also refit top panel as well and try a cycle to see how it goes.Please make sure that the water is draining out quickly and the pressure switch tube is unblocked and the fault should be rectified.If it stills comes up error 37 or your water is not draining out fast enough then reply back and I can guide you on how to clean the pump out.If the machine is draining fast and you unblocked the pressure switch tube and it stills comes up with error code 37 then unfortunately your MOTOR CONTROLLER needs replacing.Please reply back to let me know how you got on.
  • pjdkinne Aug 12, 2010
    Hi Guru,
    Sorry about the delay in my reply. We just got back from vacation . . . and left the machine in disrepair! I did as you suggested - taking off the top panel to make sure the presure switch tube is clear. I blew through it and it is clear. The water discharges quickly from the machine. It does so several times as it finishes the wash cycle. After two discharges of water (and some time between each discharge) the machine starts beeping and shows the error 37 (lights 3, 6, 8). Sounds like it is my motor controller. Right??
    I really appreciate your help in this matter. You've been persistent and thorough. Thanks
    Jeff
    Hi Guru,
    I forgot to say that sometimes the pump makes a screeching sound. The last several times I tried it, the pump didn't screech, however.
    Jeff
  • luisa_sgro Aug 13, 2010
    Hi Jeff just read your last posting.Going on the information in your posting it could possibly be your motor controller but what concerns me is the time between the discharges of water and the screeching of the pump.When the machine stops and starts to beep is the machine empty of water?If it is then my best guess is the motor controller is faulty.Now as they are not cheap I think the best plan of action is to take the controller to Your local FISHER@PAYKEL repairer and get them to test it.This way you will have a definitive answer on whether it is faulty or not.Please reply with information on whether your machine has drained completely and also how you would like to proceed.Looking forward to your reply.
  • pjdkinne Aug 13, 2010
    Hi Guru,
    The machine is not empty of water when it stops and starts to beep. It drains twice, for approximately 15 - 20 seconds. There is a pause of several minutes inbetween the draining (as if it is allowing the water to drain from the clothes). After the second draining - when there is still a good deal of water in the washer - the machine stops and begins to beep.
    Thanks
    Jeff
  • luisa_sgro Aug 17, 2010
    Hi Jeff sorry it has taken me a little bit of time to get back to you but my computer has been playing up.Now with the extra information I now am pretty sure it is your pump that is faulty.The best course of action is to ring for a price on the drain pump and if they have one in stock.I will guide you throe the removal and refitting of the pump when you obtain one.The screeching of the pump has made me decide that it must be a pump fault as I have seen this fault before.Now you must understand that without me physically testing the pump I can not be 100% sure the pump is the faulty but with the information you have supplied I am about 97 % sure the problem is the pump.Ultimately it is your decision and whatever you decide I will help you as much as I am able.Looking forward to your reply.
  • emmalmulling Nov 22, 2010
    Hi Luisa, Im just reading your replies as we are having this same problem with our machine. Do you come and look at machines at all (If you are in the Sydney area?).
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
No rinse or spin cycle but washes
Could be something as simple as the solenoid fill valves for the water if you using a different temp for rinse from the wash cycle (warm wash cold rinse) in that case the cold side of the valve could have failed, in which case you'd be getting hot water for the wash and no water for the rinse and, without the fill, the cycle won't proceed from that point.
Mar 09, 2014 | Haier Washing Machines
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
Washes OK and when it gets to the rinse cycle the machine quits.
If I recall correctly it sounds like as if the door is not locking during the cycle hence its ability to proceed further, are there any beeps or leds which will greatly help me to help you..
Cheers
Jun 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore 400 washer does the following. If I start a wash cycle it goes through entire wash cycle without draining ever, just washes until it ends. If I lift and close the lid when the timer gets...
lid switch stops machine from spinning when the lid is open, Make sure the lid is fully closed. Loose screws on the lids right side not holding metal arm properly, or the arm is not positioned properly (the end which is pointed down when the lid is open needs to be slightly farther away from you, towards the back of the machine, to actuate the switch fully: or the lid switch itself which is underneath the top,
Jan 03, 2018 | Kenmore Washing Machines
Dishwasher heats but when it starts the rinse and dry cycle the heating delay light comes on and won't proceed to the next cycle
Sounds like the heating element is not working. Usually the hot water temp is OK for the wash cycle (110 to 140 degrees) but the rinse cycle asks for 140 to 160 which requires the heating element. (As does the dry cycle).
Oct 21, 2009 | Dishwashers
The washer stops before the rinse cysle
That sounds like your lid switch. This switch is located on the top. Raise the lid, Looking down at the washing machine it is the little hole. If you push it down with your finger on mine it's grey in color. The problem is that the switch is not getting pushed down far enough. if you pull it down manually with your hand a little farther you should hear it click over and the machine might scare you as it starts up into the rinse cycle. You can purchase them pretty cheap online at any applince site.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
861 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
