Question about Dishwashers
Have a three and 1/2 year old Whirlpool sold as a Kenmore Model 665.16032403 that will not come on unless it has had breaker pulled and no power for atleast 24 hours.when it will not run the normal cycle light blinks. The delayed 2hour will also blink when pushed and the cancel button will stop both. For past few months the light to smart wash button didn't come on but washer worked. Now if washer works after no power for 24 hours the smart wash light does work.. please advise.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Sounds like a touch membrane issue
Posted on Jul 28, 2010
The broiler element comes on by itself when the power is on--it will not turn off unless I turn the power off at the breaker. The bottom element does not come on at all. I get no codes on the display
You have a bad broil-element relay on the Electronic Oven Control (EOC) - the contacts have welded shut (closed). You will need to replace the EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 28, 2014 | Whirlpool Kitchen Ranges
Kenmore 110.26492502 top load washing machine is leaking oil (yellowish with black). any chance, as a DIY-er,i can solve this? its turning 5 years old already... thanks! rex
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
The model number you provided doesn't appear on the Sears site. Are you sure it's the right number??
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Pulling the cabinet, pump, motor and gearcase are relatively easy. Getting the 8 bolts off of the gearcase and removing the top can get a bit messy as the gearcase holds 15 Oz. of gear oil. (Easily replaced with non-detergent gear oil from a local auto parts shop.
This is a Whirlpool / kenmore Serviced Manual PDF for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum. See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnectYing power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), and remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil.
You should be able to either re-seat the cover or make a thin gasket using automotive "liquid gasket seal" products.
Jan 29, 2011 | Kenmore Washing Machines
I have a whirlpool gold side by side mod# GS6NBEXRY02 lost all power, breaker not tripped power to fridge but nothing is running,fan,lights ,compressor all off. I believe this is a 2007 model and...
most all models only have a 1 year warranty,, unless you bought the extended warranty,,, anyway the issue could be in the cord or the most likely issue is the main board in the back,, most are on the back with a cover over them
Jan 24, 2011 | Whirlpool ED2FHSS Side by Side...
My kenmore is at least 6-8 years old. It has been...
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Since it will spin (somewhat) two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
May 20, 2010 | Washing Machines
No power and its not the breaker.
Some dishwashers have a thermal fuse located behind the console attached to the main board It is always helpful to include model number off unit as Sears does not make any appliances, they just sell them made by other companies with the kenmore name on them. You could have a GE, Whirlpool, Frigidaire, etc....
Mar 13, 2010 | Dishwashers
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Plese help
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Jan 24, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
