Question about Hyundai L90D+ 19" LCD Monitor
Went black. Power light still comes on. Bulb? Power supply? How to diagnose? Thank you!
  • 11,361 Answers
Caps inspection first, voltage checking next.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Jul 28, 2010
Does this TV have a replacement bulb?
hi Traci.
The online references, manuals, etc, refer to a back light, but then generally start pointing toward the backlight inverter, which is the power hook-up for the light source. They can be found on eBay
toshiba 65 ht 2 backlight inverter . Videos such as this one talk about replacing such a unit in a Toshiba, along with diagnosing what exactly has failed between power and the picture screen that's gone black.
Hope this helps!
D
Nov 18, 2015 | Toshiba 65ht2u Lcd Tv
Sony KDL42V4100 - No picture (and no menu), sound only?
There could be several things that can cause this. Could be a bad CCFL bulb, inverter, power supply problem, main board, or T-con. You will need to have the set diagnosed to track down the problem.
Aug 30, 2012 | Sony KDL-46S4100 46 in. LCD TV
Headlights wont work even with bulb replacement
dear sir
first open headlight box and remove the bulb and check by tester power supply (DC power supply ) Is coming there or not if its coming and bulb wont work then its problem in bulb if supply is not coming till headlight then check fuse box and other connector i think there any fuse is broken that's why headlight is wont working . change fuse after that headlight will work again
hope answer the question
thank you
please vote!
Oct 13, 2010 | Chrysler PT Cruiser Cars & Trucks
Engine check light stays on
If the vehicle runs fine it could be your oxygen sensor. Some auto parts stores (like AutoZone) will diagnose the check engine light code free of charge. You could also buy a handheld OBD2 code scanner and diagnose the code yourself. The scanner plugs into a connector under the dashboard.
It's pretty simple to use. A descent scanner will run about $50, and you can use it to diagnose codes on all your vehicle's thereafter.
Jul 15, 2009 | Codegen 4063B-CA Black/Silver with 400W...
Power supply light green but does not work
Check this site out it has everything you need to know about repairing the 360's and diagnosing such problems. http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm My name is Tim Ehrhart and I hope this helps you out. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 11, 2009 | Microsoft Xbox 360 Console
Sony vaio desktop wont turn on
This type scenario normally indicates a power supply failure. Try connecting a known good power supply to your Sony Vaio desktop.
If you do not have a spare power supply, (many people do not) the alternative is to short the the black and green wire on the power lead connecting to the motherboard using a paper clip. This is not a desirable solution and very dangerous, but will help to diagnose the problem. Do not insert any objects while the power supply is energized. Ensure it is unplugged first.
Should the computer start with the green and black wire shorted, the problem is with the power supply. If not, the problem is likely at the motherboard level.
Hope this helps you.
Dec 29, 2008 | Sony VAIO VGC-RB42G PC Desktop
Black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Philips 50PFP5332D 50 in. Plasma...
No Picture on LCD TV
The back lights can burn out, also the power supply capacitors leak and blow out. The bulb(s) are a tough fix, the capacitors are somewhat easier.
Apr 21, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Power supply
Hello enirehtac
HERE is a link to HP's instructions for trouble-shooting power supply-related issues.
Please, follow the steps outlined there and post back here w/ the results, your observations, and any comments or questions you might have.
** Please, don't assign a rating to any of
** the experts' recommendations until your
** problem has been resolved or diagnosed.
** Once ratings are assigned, the problem
** will be closed and we won't be able to
** continue to assist you. We WILL keep
** working w/ you until your problem is re-
** solved or diagnosed.
Thank you
BJ @:)
Apr 11, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
377 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
