Question about Canon PowerShot S5 IS Digital Camera
Camera only takes one or two pictures then message tells me to change batteries. Batteries are new and camera turns off.
After surveying the web, I see that this problem has been around for at around 3 years. I use fully charged NiMh batteries and get the “change batteries” message after only a few shots or immediately.
In my case, changing to alkaline 1.5V batteries solves the problem (versus ~1.3V for NiMh or other rechargeables.) Cleaning the contacts (stainless steel) makes no difference.
Interestingly, I can operate the camera in the playback mode and view pictures and movies with no problem. This involves driving the display on the camera back, probably the most power hungry part of the instrument. This suggests the problem is record mode specific.
My guess is that there is a voltage reference problem. References can drift over time, and depending on the initial value, cause problems any time during a camera's life. The reference isn't necessarily needed in playback but is critical for recording should the image sensor voltage be too low.
Posted on Aug 24, 2010
SOURCE: Change Battery Message
I had the same problem - I think the battery was not being held in far enough by the battery cover, this cured my particular problem yours may be the same. Try a thin piece of card (less than 0.5mm thick) about 5.0 mm wide folded in a U shape over the top of the battery. This will 'push' the battery in just a little further. If the battery cover is a little tight when you try to close it your card is too thick!
Posted on Aug 25, 2007
MrsJGreen
  • 130 Answers
SOURCE: s3 is issue
E18 is a lens error that needs to be serviced by Canon technicians. You may qualify to replace your S3 for a flat rate or to repair, but it is nothing that you can fix at home.
As for the batteries, what brand? If they are rechargable, make sure they haven't been drained-try them in another device perhaps. I drained mine by leaving them on the charger too long and I had the same issue. Try another set of batteries and clean the battery contacts inside the camera with a pencil eraser to get rid of any residue or oxidation that may have taken place.
If none of this helps, call Canon for service or other option to upgrade for a deep discounted rate. Sometimes it's cheaper than to fix it if you are out of your one year manufacturer's warranty.
Hope this helps!
Posted on Jun 01, 2008
dlundmark
  • 797 Answers
SOURCE: BATTERY EXHAUSTED
Make sure you have the internal menu for the battery selection correct.
Choosing the wrong battery may cause this.
Rechargeable batteries and alkaline batteries are not the same.
This may also be a condition and problem caused by the camera itself, and may need repair.
Posted on Sep 23, 2008
  • 11967 Answers
SOURCE: batteries drain after only 5 or 6 pictures
New camera?...take it back.
Posted on Aug 25, 2009
SS PAI
  • 55 Answers
SOURCE: ''change the battery'' message
Cross check that the batteries u inserted are compatible with the camera.
Hope this helped sir..
Posted on Jan 05, 2010
I put in new batteries...the camera works fine for four or five pictures and then the battery message comes on that I need new batteries. Sometimes that message comes on before I even get to take a...
Same here, not the batteries
1.2v rechargeable Radioshack 1600mah & 1500mah did work though...
If you eventually get it to boot, go to menu and pick coolpix batteries.
Apr 07, 2011 | Nikon COOLPIX L20 Digital Camera
IT KEEPS TELLING ME TO CHANGE THE BATTERIES (EVEN WHEN THEY'RE NEW BATTERIES) AND SHUTS DOWN COMPLETELY.
Couldn't find a firmware upgrade for my Canon PowerShot A720. Tried putting a piece of rubber under the spring on the lid to make it tighter and it helped because I can take more pictures before I get the dead battery message (even thought they aren't dead). I bought the Duracell that you can check the charge on because I'm sure I've wasted dozens of batteries by now.
Aug 31, 2010 | Canon PowerShot A720 IS Digital Camera
CAMERA WON'T LET US TAKE A PICTURE
Make sure you are using either NiMH rechargabeles or quality name brand alkalines to get rid of the change battery message. As for the balck screen, it is likely that the shutter is jammed closed and the camera needs to be cleaned / serviced.
Jun 09, 2010 | Canon PowerShot S3 IS Digital Camera
Jan 05, 2010 | Canon PowerShot A550 Digital Camera
Batteries drain after only 5 or 6 pictures
Aug 25, 2009 | Cameras
Cannon A590 "Change the batteries" after replacing new batteries
Off-the-shelf NiMH rechargeable batteries, and the special lithium nonrechargeablebatteries sold as esepcially good for camera use, don't have enough voltage output for this camera. Try using regular alkaline batteries or the rechargeables sold by the manufacturer.
Mar 27, 2009 | Canon PowerShot A570 IS Digital Camera
Short battery life?
I had a smiler problem with Alkali batteries. Thereafter I started using rechargeable batteries and also changed the setting to Ni-MH. Its working fine now.
Feb 26, 2008 | Nikon COOLPIX L10 Digital Camera
Depressing my shutter button on my Fuji FinePix E550 causes it to turn off. When I turn it back on there is a no image message. Is it cheaper to buy a new camera than to have it fixed? Thanks for help
You just need new batteries. That's what the E550 does when the batteries get too low. Please get the latest rechargables. Many of the ordinary AA batteries won't last 50 pictures. Fuji also is rather poor telling you how to charge the rechargables. When the screen goes blue when you take a picture, you must use the camera's de=charging system before recharging--otherwise the rechargables will not take a full charge--that's what's likely happened to you!
Feb 15, 2008 | Fuji FinePix E550 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
