Question about Frymaster Dean SR42G Deep Fryer
Fryer pilot will not light model # sr42gn btu 1050
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Posted on Nov 12, 2009
Hi there, Im wondering how to get a new pilot light part for my pitco fryer. Or will it take other brand Pilot lights? Cheers
It is usually best to use the same parts for the fryer but most of the time they are what you would call a generic part that is used by many. If you have a pilot that will fit it should work. But like I said it is best for optimum performance to use OEM parts or same model parts.
Oct 29, 2014 | Pitco Frialator SG18S Deep Fryer
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
My fryer model SRTG LIGHT THE PILOT BUT WON'T LIGHT THE MAIN BURNER
check if the thermopile (cylindrical metal standing behind pilot assembly) receives enough heat from pilot flame. if it does, you need to replace the thermopile.
Mar 30, 2011 | Pitco Frialator SG14 Deep Fryer
I am converting a pitco model 14c fryer from nat gas to propane, and am wondering where does the pilot oriface install at. It looks like a small cap with a hole in the end. Thanks Jim
The pilot light is attached directly to the front of the pot near one of the burners. You will see one small gas line and a set of wires. Loosen the nut where the gas line goes into the pilot light. You will have to hold the pilot light as well as turning the nut on the line. Pull the line from the pilot light assembly. Sometimes the pilot orifice comes out with the line and other times it stays stuck in the pilot light. If it is stuck take a small blade like a pocket knife and pry it out. put the new one in and tight it all back up
Oct 02, 2010 | Pitco Frialator SG14 Deep Fryer
The pilot lights ok,the burners light,but after sometimes 5 to 10 minutes later both will go out
The gas for both passes thru the FMDA Safety Valve - in you case it's defective and must be replaced. You can find it here
http://midwestapplianceparts.com/stove-oven-range-58/vulcan-hart-parts-773/oven-safety-valve-1050/vulcan-hart-fmda-safety-valve-6253.html
Oct 02, 2010 | Vulcan EF3 Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Frymaster Dean SR42G Deep Fryer Logo
88 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
