Question about Westinghouse Washing Machines
Lint on the clothes. The machine has an automatic lint filter. How do I get rid of this problem?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Automatic lint filter means it goes out the drain when the water drain, nice how they make that sound all fancy huh. make sure there is more water than clothes and whatever your washing is not delicate you have to wash delicates with the delicate cycle
Posted on Jul 28, 2010
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Where is the lint filter? Why does it put lint all over clothes?
lint is usually removed in the dryer. If you have lint on clothes after going through the wash, you probably left something in a pocket somewhere.
Sep 20, 2014 | Maytag Washing Machines
Kenmore 400 washer, leaves tons of lint on clothes, no lint basket to clean, cleaning the inside of the washer doesn't help. Black clothes have to be brushed completely with a lint brush to be wearable....
most common cause is that a tiisue or something of that nature went into your wash it breaks uprt and is scattered inside the machines outer bowls,either remove inner bowl to clean it or put it several empty washes to try and get rid of it
Oct 24, 2017 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Clothes are collecting a lot of lint when washing. Is there a lint filter? I have already tried running vinegar through a cycle.
not knowing the make and model,, I can offer you this ,, if your machine actually has a lint trap it will be located right before the pump under the machine, also,, try using a little more detergent, this helps cut down on the lint left in the machine and on clothes, if you reply to this feed i will try and locate your machine and check on the filter
Jul 24, 2011 | Washing Machines
Have had machine for 3 yrs - had no problems until recently when there now is a li\ot of lint on the clothes. i have changed detergents but this has not helped
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Jan 09, 2011 | Whirlpool Washing Machines
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
After wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
98 people viewed this question
Top Westinghouse Washing Machines Experts
Mack Baxter
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
