I have a 3com 3CRWER100-75 router. I have seen a new firmware version - 1.3.14. Downloaded it from the 3Com site, unzipped it and started the upgrade. After 2% have been transferred, the connection stalled. After a good 15 Minutes, I tried to restart the router, but lost connection. Pressed the reset button for (more than) 5 seconds, but no reset effect is seen on the leds afterwards. After power off and on - no connection. On its bootup, the leds play a little, and with a sniffer I can see that the router sends the 3 ARP who has messages: "Who Has 10.10.12.72". It does not respond to pings (no matter if the ping is sent to the manual designated "default" 192.168.1.1 or to 10.10.12.72). Any ideas how to get the damn thing back to a useful state?
  • Amit Dar Jul 28, 2010
    Very knowledgable, but unfortunately no cigar.
    It seems that if the problem is sourced in a defective product, it is sometimes too hard to solve.
    Anyway, Tahnx for the help.
  • 6,487 Answers
Base from the description of your problem the router got corrupted because of the unsuccessful firmware upgrade, so lets do here a different way of reset , follow this steps Press and hold the reset button for 30 seconds and while you're still holding the reset button unplug the power of the router for 5 seconds but don't let go the reset button yet after 5 seconds power it back on and then let go with the reset button.
Then after that check the IP address of the computer that is connected to the router wired and then try to ping the default gateway.
Posted on Jul 28, 2010
  • 3 more comments
    Hi, thanks for the prompt reply. Unfortunately no cigar. The router does respond to pulling the power jack out (...) bit does not seem to respond to anything else - especially not to start pressing or releasing the reset button. The only change I can see is addition of two more ARP "Who Has 10.10.12.72" message sent by the router, summing up to 5 instead of 3.
    The router does not respond to ping messages (both to 192,168.1.1 and to 10.10.12.72), nor does it respond to any messages sent on the local net (DHCP and others).
    I have opened the plastic cover to see the circuit, and found the following:
    The main chip is IP175C LF which is an SOC implementing a switch.
    The only other chips (leaving aside the covered RF zone,and a few analog filters and transistors) is NT5SV8M16DS - 6K that seems to be an SDRAM.
    and 25P32V6P that seems to be the serial FLASH
    I can see a non populated 9 pin port that may embed a JTAG connection.
    Not much to work with, I'm afraid.
    Any more ideas?
  • Mark Gil
    Mark Gil Jul 28, 2010
    OK can you tell me first what is the IP address that the computer is getting when connected wired to the router.
    Thanx again.
    here is the scenarion recorded by EtherRael after router power up (the router is connected to the PC only, and the PC nic is set to DHCP - automatic detection of all):
    No. Time Source Destination Protocol Info
    1 0.000000 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 1 (60 bytes on wire, 60 bytes captured)
    Ethernet II, Src: 3comEuro_fb:73:2c (00:0f:cb:fb:73:2c), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Address Resolution Protocol (request/gratuitous ARP)
    2 0.302380 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 2 (60 bytes on wire, 60 bytes captured)
    3 0.604778 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 3 (60 bytes on wire, 60 bytes captured)
    4 0.645439 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0xfba7b186
    Frame 4 (342 bytes on wire, 342 bytes captured)
    Ethernet II, Src: CompalEl_49:d3:cd (00:0f:b0:49:d3:cd), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
    Internet Protocol, Src: 0.0.0.0 (0.0.0.0), Dst: 255.255.255.255 (255.255.255.255)
    User Datagram Protocol, Src Port: bootpc (68), Dst Port: bootps (67)
    Bootstrap Protocol
    5 0.907386 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 5 (60 bytes on wire, 60 bytes captured)
    6 1.209795 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 6 (60 bytes on wire, 60 bytes captured)
    7 1.512188 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 7 (60 bytes on wire, 60 bytes captured)
    8 1.814554 3comEuro_fb:73:2c Broadcast ARP Who has 10.10.12.72? Gratuitous ARP
    Frame 8 (60 bytes on wire, 60 bytes captured)
    9 3.646679 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0xfba7b186
    Frame 9 (342 bytes on wire, 342 bytes captured)
    Bootstrap Protocol
    10 11.649232 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0xfba7b186
    Frame 10 (342 bytes on wire, 342 bytes captured)
    Bootstrap Protocol
    11 26.655984 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0xfba7b186
    Frame 11 (342 bytes on wire, 342 bytes captured)
    Bootstrap Protocol
  • Mark Gil
    Try to set static IP address on your computer that is wired to the router with this range 192.168.1.X and then try to PING it again, but if still not being able to PING a firmware flash here using JTAG is the next thing that you can do.
    Thanx.
    I have already tried setting the PCs nic to static 192.168.1.X - to no avail.
    Do you have by any chance a link to anywhere that suggests or describes the JTAG to use for this router? Could not find it in 3COM's site. In addition, assuming I can get the appropriate JTAG adapter, do you know where to get a JTAG loadable version of the router firmware?
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
I need firmware for 3Com WL602
You can download the firmware from this WEB site.
http://webtopicture.com/download/download-3com-wl--firmware.html
Dec 11, 2012 | 3Com OfficeConnect Wireless 11g Cable/DSL...
We have a 3CRWDR101A-75 3com wifi router and its not upgrading the firmware, I downloaded the firmware from the site and then when I try to upgrade all I get is file verification failed... any thoughts...
The downloaded file is "corrupt", and thus it fails the "verification" process.
Download the firmware again, and compare the two files.
Or, use a different computer to download the firmware, and to do the firmware-update.
Apr 20, 2011 | 3Com OfficeConnect Remote 612 ADSL Router
I have used 3com router 5009 series and the software version of the router is 1.20...any idea if i can upgrade the version/firmware to another latest version...
The 1.3 update is listed on this 3Com link:
http://www.3com.com/products/en_US/result.jsp?selected=all&sku=3C13700&sort=effdt&order=desc
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2011 | 3Com Router 5009 (3C13700-US)
How to change software version of 3Com router from 1.20 ver to another latest version because it not support a lot of command for configuration.
Usually the software version of routers is called a firmware. You will need to download the latest frimware version from there website and upload it to your router through its configuration page.
You get to the configuration page through the routers ip address, usually its 192.168.1.1 or 192.168.0.1, you will need to type this into a web browser.
Mar 06, 2011 | 3Com Router 5009 (3C13700-US)
Please Help When I try to enable my Apple MacAddress at 3Com router wl-537 it informs nota a valid macaddress. What can be done?
I had the same problem with the Ipod of my son.
To solve the problem, just upgrade your Firmware to the latest version. This will allow u to define the new MAC address. But the problem is that this firmware version doesn't work well, reseting the router every couple of hours. So to solve this problem, after you upgraded the FW and defined the MAC address, downgrade the firmware to you previous version, the new mac address will still there.
This workaround you need to do every time that you want to define any new MAC address
Feb 19, 2011 | 3Com OfficeConnect® WL-537 Wireless Router...
3com 3crwdr200a reboots every 30 minutes
The 3com website is remarkably shoddy on this issue, and doesn't have the newest required updates. Even the KB on their site is thin on solutions.
You really need firmware 3.6.4, yet 3.0.1 is the latest on the official website. Try this page:
for the very latest firmwares, and note that it's best to clear out the router memory completely before adding the new firmware to it. This is because it sometimes doesn't like the new image files otherwise. The way I suggest:
1. Note all of your settings manually (don't save a config file, it may not read back in).
2. Hard reset and clear the memory, by holding down the reset button and powering on.
3. Connect to 192.168.1.1 with your browser - you may need to mess with the network settings on your PC to get it to connect. You will see a very bland screen, asking you for a firmware file, rather than the traditional login screen.
4. Upload the latest firmware, downloaded from the site above.
5. Allow the router to do it's business and restart.
6. Connect back to 192.168.1.1, and you will once again see the correct router software, with a new install wizard.
7. Re-enter all your settings, as noted above.
May 04, 2008 | 3Com OfficeConnect Wireless Router
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
112 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
