Washer will not start at all. There is nothing on the display screen, its completely blank. I have checked the belt, inlet valve screens, trap at the discharge pump, power outlet, water supply and all are okay. There is no corrosion on any connectors. I replaced the door lock module last year. I have re-installed the back, front and top panels. Any suggestions on where to look next?
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
Can you provide the model number and the brand name of the machine.
With that info I may be able to help you as some machines have fuses in them which can manifest in the way you`re describing, if faulty.
I`ll watch for your reply.
macmarkus :)
Posted on Jul 28, 2010
  • peterfj Jul 28, 2010
    Oops, sorry about that....its a Whirlpool Duet HT, model # GHW9250MW1.
How do I fix F20 code
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
What does F20 on the washer mean?
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
I have a kenmore elite and the code f20 error keeps coming on and it will not get warm
Nov 04, 2012 | Washing Machines
Ge toploader whse5240D1WW will not fill with water
please the causes and remedies: God bless you
f your Top Load Washer Has No Water Entering Check The Following
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control.
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | GE WHSE5240D Top Load Washer
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Wfk2801 no water input for final rinse. Cold water input for main wash ok Also pre-wash not working Thanks Bary Wiggins
you mean the rinse cycle is not starting or the water alone is flowing for rinse cycle?
Jul 13, 2008 | Bosch Washing Machines
LF error on my washer
Have you checked the filter screens at the washer inlet valves?
If the hot and cold water supply to the machine is good, and the filter screens on the washer inlet valves are clear..Then the inlet valves have failed and will have to be replaced.
Jun 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Duet washer WFW9200SQ00 display F20
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
Apr 16, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
