My control lock is on and do not know how to take it off
  • 240 Answers
Usually a button to press and hold for 3 seconds. should be labeled on front. GE is at top by start button
Posted on Apr 24, 2008
Need to remove center console in 2007 buick Lucerne, stuck in park
Do you know why it's stuck in park ? Do the brake lights work ?
Automatic Transmission Shift Lock Control Description and Operation (Floor Shift)
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM)/powertrain control module (PCM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The BCM controls the voltage supply circuit of the shift lock control solenoid. The following conditions must be before the BCM will supply voltage to the shift lock control solenoid.
The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will supply voltage to the shift lock solenoid:
• The ignition is in the ON position.
• The ECM/PCM sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
• The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically unlocking the shift lever allowing the driver to move the shift lever out of the PARK position as the solenoid energizes. When the brake pedal is not applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid mechanically locks the shift lever in the PARK position.
During remote start operation, the BCM will de-energize the shift lock control circuit, locking the shift lever in the PARK position.
Do you know what DTC'S are ?
DTC B2705 Gearshift Unlock Circuit !
The body control module (BCM) controls the shift lock solenoid by providing battery voltage to the shift lock control solenoid. The BCM utilizes a smart driver to control the voltage supplied to the shift lock solenoid. The smart driver monitors the voltage and current flow of the control circuit.
Transmission Control Lever Malfunction (Floor Shift)
Circuit/System Verification
Ignition ON, while pressing the brake pedal, observe the scan tool Brake Applied Output Signal parameter. The reading should be ON with the brake pedal pressed.
? If not the specified value, refer to Stop Lamps Malfunction .
Press the brake pedal, the vehicle operator should be able to move the shifter lever out of the park position.
With the vehicle moving over 5 km/h (3 mph), the vehicle operator should not be able to move the shift lever into the reverse position.
May 25, 2017 | Buick Cars & Trucks
Rear doors will not unlock
Door Lock System Components
The power door lock system consists of the following components:
The driver door switch (DDS)
The passenger door switch (PDS)
The driver information center (DIC)
The rear door lock/unlock relay (LBEC)
The door lock actuators in each of the doors The rear passenger doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Do you know what the BCM is , body control module ! If you do not know about this stuff I strongly suggest you to it to a ASE certified repair facility ! Save yourself some money an aggravation !
Apr 17, 2015 | 2007 GMC Sierra 1500
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Control Lock?
If the controls are locked push and hold the cycle selection button on right side of control panel for 3 to 4 seconds to unlock. (sometimes this gets pushed without knowing it locking the control panel) good luck.
Aug 06, 2010 | Whirlpool Dryers
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Controls locked
The following link explains how to correct a control lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these instructions do not correct the problem for you, please post back and let me know. Your problem may be something more than just a simple operator control issue. If you have any questions, please let me know. I hope this helps you.
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control lock is on and don't know how to turn it off
Without knowing the manufacturer and model number, it is impossible to be specific. But most dishwashers that have a control lock light means that you have a child safety feature on the dishwasher. If you look closely, you may see some symbol that ties two buttons together and maybe if you press both at the same time, the child lock out may turn off.
Post info about the make and model here to get more specific.
May 06, 2009 | Dishwashers
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
