Question about Sevylor 48 in Inflatable River Tube
I need a replacement tube insert for Sevylor triple x U330 towable
WHERE IS THE AIR NOZZLE TO FILL THE SEVYLOR FLYING MANTA RAY LOCATED
All the Sevylor tubes have a valve that comes apart in to two pieces, remove the top and you can fill remove the hole thing releases the air. You need a 12 volts high volume low pressure pump with connectors, 20 bucks in Overtons. Fill it till it is stiff, put it in the water let the air cool down inside then hand fill it with the connector and human breath to stiff it up again.
Sep 07, 2010 | Sevylor 48 in Inflatable River Tube
Protruding tube
I sell on eBay and I just went there to check for you. There is a lot of them there-not sure if its what you need exactly. Put in ebay search sevylor tube. Hope this helps burdfrenzy
Oct 17, 2009 | Sevylor 48 in Inflatable River Tube
Sevylor motor mount instructions
I dont believe a motor will mount to it. Sorry!
Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
What is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Sep 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Have a leak in my tube in my super mable inflatable raft
Use Sevylor Seam Seal...liquid gold it will fix it try www.twister.com.au they sell it!
Jul 15, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Vinyl air
I have a vinyl towable tube inflated with air.....I need to know how the best way is to patch this to hold air under pressure
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
From what is an Inflatable Towable made of?
AN INFLATABLE WATER TUBE IS GENERALLY CONSTRUCTED FROM AN ENCLOSED FLEXIBLE PVC RUBBER BLADDER AND SURROUNDED BY A NYLON FABRIC COVER. MOST TUBES CONTAIN A VALVE THAT ALLOWS THE RIDER TO INFLATE THE TUBE MANUALLY OR BY WAY OF AN AIR PUMP. RIDERS SHOULD LOOK FOR TUBES THAT HAVE ENOUGH HANDLES TO ALLOW THE RIDERS TO SAFELY AND COMFORTABLEY RIDE.
Sevylor 48 in Inflatable River Tube Logo
117 people viewed this question
Top Sevylor Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sevylor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
