Question about E-Machines eMachines Desktop PC
My mother board
I tried to add some more memory to my computer and it beeped then i turned it off and took it out leaving the one that was in their from the start it worked at first then I powered it down and the next morning i turned it on and it beeped three times and wouldn't come on the fans came on but no screen
    Guru:
  • 1,342 Answers
Take the memory stick back out and put it in again. Make sure that it is seated firmly.
Posted on Apr 23, 2008
I have a dell inspiron 545. I lost my display and the computer now beeps four times, pauses and beeps four more times. Can you tell me what happened to my computer?
This is normally a memory error. Turn off the computer, and open the side of the case. Pull and re-seat all memory chips. Turn power on, if it still beeps. Turn off power, pull all the memory chips and re-seat one only. Turn on power if it beeps againg, pull the chip out and try the other one. Repeat for all chips. If you find any that do not cause the beep issue, you have found your bad memory chip. If not, try the same one at a time memory test in a different slot on the computer. If no beeps, then its a bad slot and dont use that memory slot.
If none of this works; as unlikely as it seems you could have all bad memory chips, or a bad mother board.
Jun 12, 2012 | Dell Computers & Internet
Turns on, then shuts down before anything shows on monitor
Hi m5mm, what kind of Operating system are you using?
Jan 03, 2008 | Gateway GT4022 PC Desktop
Dell inspiron has no display and beeps four times and then pauses and beeps four more times
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
3 beeps are heard when I start my computer
This is a BEEP CODE telling you that the computer cannot POST, check all ardware (RAM, PCI cards etc...) take out every thing you can leaving just the minimum (mother board, CPU and power) than put stuff back in one at a time and reboot each time you put in something (starting with the RAM) again one RAM module at a time... until you find the defective component...
Jul 25, 2011 | Gateway 825GM PC Desktop
L4S5MG/651+ P4 mother board, no display on power
Hi jayson_rees,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 04, 2009 | EliteGroup L4S5MG/651+ Motherboard
My comp wont boot up
Try reinstalling the OS, I hope this will resolve this issue.
Aug 02, 2009 | Computers & Internet
Mother board asus a7v133
Hi there.
No i doubt its the chipset but rather the system memory.
Pull the power cord from the back, open the side panel, get a clean dry soft paintbrush, take out the system memory and clean the brass pins and the ram slots of any dust that may have built up, then reseat the memory making sure it clips into place nice and tight and try to boot the computer up again.
If you still get beeps count how many there are and if they are long or short and post back here.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | ASUS A7V133 Motherboard
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
