Question about Hamilton Beach Kitchen Appliances: BrewStation Dispensing Coffeemaker
What does it mean when it says pour water but i have water in it
My brewstation did the same thing. I put the water in the proper area, and it still stated "pour water" so I removed the water, took off the coffee basket, removed the coffee "bucket" and laid the coffee maker on its side, on top of a towel. I came home later that day and tipped it completely upside down (removing all possible water from the system)
To my surprise, some coffee grounds came out with it. Apparently, if any grounds get caught in siphon system, it can jam it shut. Then the system is not able to remove water from the reservoir, and thinks there is no water.
Hope this helps
Posted on Aug 10, 2010
  • grungekeeper Aug 12, 2010
    here is the response I got from Hamilton Beach
    To bypass the pour water alert press and hold the power button for 3-5 seconds.
    Thank you for contacting Hamilton Beach.
  • Ivy Haasen
    Ivy Haasen May 07, 2018
    I tried that and it brewed cold water
  • 906 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} LINK
Hi Guest,
Pour water means to put water inside it. I have here a manual for your easy reference.
Thank you
Posted on Jul 28, 2010
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Plastic elbow
It would be nice to know what engine your Skylark is equipped with and what plastic elbow you are talking about. When you say "water" do you MEAN water? or are you talking about engine coolant (antifreeze)?
I have no clue if you are talking about the A/C evaporator drain (in which case, water is SUPPOSED to pour out of it) or if you are talking about the thermostat housing for the engine cooling system.
Apr 14, 2012 | 1997 Buick Skylark
Why is our coffee maker brewing only half a carafe after filling with a whole carafe of water?
There is different reasons one being that it is a gravity/syphon system. Meaning as you pour cold water into the tank it forces the hot water up through a tube. What you may need to is simply pour water in until you see the water start to trickle out of the sprayhead that will let you know the tank is full. Like any container the water heat will eventually start to disapate. Once you have filled it to where you can see the water trickle out of the sprayhead allow a d\few minutes for the heater to heat up to temp again. Then you should be able to pour in a FULL carafe and get the results you are looking for. Or you could always look on bunnomatic's website for one that hooks up to water line and eliminates the need to pour any water in. www.midstatebeverage.com
Nov 16, 2010 | Bunn VPR Coffee Maker
Water dripping into the refrigerator area from the freezer
Means you have a clogged or iced drain. Remove rear panel in the freezer and pour hot boiling water into drain. Inspect to ensure it is not iced. Keep pouring hot boiling water into drain until it opens and starts to drain. Be sure to put towels on top shelves in refrigerator to catch water, then dry completely.
Feb 08, 2010 | KitchenAid Refrigerators
Unit does not brew all the water from the resevoir
This usually means that you need to get a new coffee maker.
Nov 19, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Replace cooling fan termstat and vehicle still over heats
Thermostat
Test thermostat in a jug and pour boiling water on it , it should compress meaning it works. Check that the waterpunp is operating pushing water into the engine .Check that radiator water flows to the watrpump. Is tension of fanbelt of waterpump sufficient that it doenst slip. Lastly check that the radiator fan is working if has a electric fan. if this doesn’t help check if radiator or engine water passages isn’t blocked.
Aug 29, 2009 | 1995 Pontiac Sunfire
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Anyone solve the pitchers in puzzle 78
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Apr 24, 2009 | Nintendo Professor Layton & the Curious...
Water/Coolant pours out of engine as soon as I put it in.
It has popped the freeze plugs out and you won't know the extent of the damage it has made till you replace the freeze plugs. You never i mean never pour water into a vehicle around time for freezing weather
Dec 24, 2008 | 2000 Ford Taurus
Hamilton Beach Kitchen Appliances: BrewStation Dispensing Coffeemaker Logo
3,998 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
