Question about Canon imageRUNNER 400S Copier
How to remove canon ir 400 paper feeder assembly
  • Canon Expert
  • 1,326 Answers
Why???? The unit comes out the right side of the copier. There are alot of screw to be removed. You can take the paper trays out and remove a paper jam and also replace the rollers. If the paper tray is not lifting? There is a lift gear that breaks and it is not easy to replace> I have over 20 years and it is not easy to do......
Posted on Jul 28, 2010
Canon ir 2420 shows paper jam when there isnt any
HI,
This is happen due to printer feeder problem.... pls check feeder and clean carefully.
Thanks,
Nov 11, 2014 | Office Equipment & Supplies
Automatic feeder on top is not picking up the paper?
Odds are that a paper sensor flag is knocked out of place and show a constant paper jam. It is a flaw of the feeder. The sensor is inside the door of the doc feeder. You will need a service person to repair it. I have done it many times..... Good Luck
Jul 05, 2012 | Canon IR-1022 Copier
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
How to solve E051 error please guide me...my machine is canon ir 400, problem started immediatly after starting the machine, i cleared the error by pressing addl fn+2+8&addl.fn but it didnt solve it....
This is failure of the horizontal registration motor. I've had to replace this motor and it's a very involved process. This is the very small motor located just above the paper pick-up assembly. If you're not a qualified tech then let a tech take care of it for you. You have to remove several covers, P/U assembly, and other things to get to it.
Jun 27, 2011 | Canon imageRUNNER 400S Copier
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Hope this is of some help.
Ed
May 06, 2009 | Canon imageRUNNER C3200 Copier
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon imageRUNNER 400S Copier Logo
188 people viewed this question
old marine
old marine
