Question about Dishwashers
My dishwasher is getting power supply properly. but it is not starting up . i can hear a sound but nothing else. what should i do . i have checked all drains as well . light is on but it is not working
    Problem Solver:
  • 11 Answers
Confirm the machine is filling with water. There is a water level switch that will prevent the machine from going into wash mode unless the proper water level has been achieved.
To test the switch, manually fill the bottom of the unit with water using a pitcher. Close the door and if the machine begins the wash cycle then the problem is the fill valve solenoid.
Hope this helps..
Posted on Jul 28, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Yea need more info than that, does it have a timer or a control board, brand would help
When I push auto and start the lights go on and the time, but then it goes off. Why?
Hello. Is this unit less than 1 year old? If so, anything defective is covered under the warranty(parts and labor). After 1 year, certain parts are covered, however, no labor is covered. Make absolutely sure the door is closed properly--there is an internal door switch that must be closed(tells the main board it's okay to start the cycle) or nothing will happen and produce the exact symptom you describe. Next, the unit could be experiencing an error condition causing the shutdown. Make sure the water supply to the dishwasher is turned on(and always run the hot water in the sink before starting the dishwasher to ensure hot water gets to the unit). Next, do you hear the drain pump working? A lot of dishwashers turn on the drain pump immediately to remove any standing water in the pump before letting in fresh hot water. If the drain pump is jammed or clogged, you might hear a soft humming sound only(from the motor trying to spin) and then the dishwasher will shut down due to it detecting a malfunction. Check the float switch in the tub to make sure nothing has gotten underneath it(ex. a spoon or fork can become lodged underneath and the dishwasher thinks there is already water inside and won't fill) I hope this helps you!
Oct 12, 2015 | Maytag MDB4949SDH MDB4949SDH Dishwasher...
CAPLE D1475
try removing power supply and then back on it will reset the CPU
May 26, 2014 | Dishwashers
I loaded my dishwasher lastnight as normal closed it and hit the start button and nothing happend. its like it has no power! what can i try before calling someone?
first check electrical supply,second check switch continuity,3rd check door switch or reed switch if contact properly.
Aug 12, 2010 | Dishwashers
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher Not Getting Water
The water inlet valve could be faulty or possible some obstruction in it.
Aug 12, 2017 | Frigidaire Dishwashers
When dishwasher cycle is started no water enters the dishwasher.Hoses and filters checked and all O.K.Power supply is on.
make sure water is on to dishwasher. second, check the float switch to make sure it is working properly. the float switch is located inside the dishwasher in the front. just lift up on the float and back down and make sure you can hear the switch clicking. try and run unit.
if that doesn't work, take of the bottom kick panel and remove the wires to the water valve. with an ohm meter on voltage, turn the dishwasher on and make sure there is proper voltage going to the water valve. if that is ok, either your water valve is plugged or bad. Joe
Nov 18, 2008 | Bosch Dishwashers
Water does not go in
First make sure that there is nothing on the bottom of the dishwasher tub where the float switch is located. Different machines locate them in different places on the bottom of the dishwasher tub below the bottom rack. If you pull the bottom rack out and find a plastic float and move it gently up and down you will probably hear a clicking sound. That is the switch inside the float. if that works and nothing is hindering it then go under the sink or where ever your water to the dishwasher is getting its supply and make sure the the valve is turned on and there are not leaking problems there. It these things do not work then I would start thinking on the pump being bad or the control panel for the cycles not working properly. Would need make and model number to help with that one... Hope this helps ya.
Oct 11, 2008 | Thermador DW44Z Built-in Dishwasher
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
No power to dishwasher
depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
May 09, 2007 | Frigidaire GPDB698SSBK Dishwasher
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
