Question about Toshiba 1370 Black and White Copier
I was just given a Toshiba 1370 copier. I also received a drum and blade kit and toner but I don't know how to fit them. Can you help?
    Problem Solver:
  • 5 Answers
What is CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Feb 02, 2014 | Toshiba e-Studio 232 Black and White...
The & symbol is on the screen - does this mean the copier needs toner?
i am having toshiba 1370 printing is not clear words are repeatin in paper tell solution
Jan 30, 2013 | Toshiba 1370 Black and White Copier
Toshiba estudio 167 - time for maintanence appear so what can i do??
hi
you need to replace some parts on the copier (consumables)
KIT - 2340 Developer Maintenance Kit - Kit Includes: Drum Blade, Recovery Blade, ( 2 ) Drum Picker Finger, Main Charge Grid, Main Charge, ( 2 ) Transfer Separation Wire, Developer - Genuine Toshiba Part -- resells for about $240 , youc an buy this at any online store .. example , http://www.precisionroller.com/maintenance-kits-for-toshiba-e-studio-166/details_57969.html please rate me 4 thumbs up
Dec 29, 2010 | Toshiba E-Studio167 Copier
Copier has double imaging in dark down the middle of paper
Your drum cleaning blade has gone bad. The blade cleans the drum between copies. When they go bad they can not keep the drum clean and some of the toner from the previous page is left on the drum and is reprinted along with the current print. The toner also builds up which is what causes usually the dark band where the double imaging occurs. Pretty cheap part at around $30. Just need someone who can install it for you. I would estimate the total cost to be around $125 to $150 depending on your local labor rates.
Good Luck and Thank You for using Fixya.
We are having a contest this month based on customer testimonials. If I have helped you with your free question today could you please leave a testimonial.
Thanks!
Oct 07, 2010 | Toshiba 1370 Black and White Copier
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
May 19, 2009 | Toshiba DP5570 Laser Printer
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
Sharp COPIERS - AR-5316
The cleaning blade is in the drum cartridge.
There is no developrer change in that product.
There are 2 cartridges.
The toner and drum.
Toner contains all you need as far as ink. And also the waste sump is on the toner cartridge.
The Drum is a self containted unit that has the cleaning blade and auger built in.
Jan 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Toshiba 1370 Black and White Copier Logo
109 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
