Question about Star Manufacturing International Star TSP100 Printer
My star tsp100 won't print it worked befor but now it will spit out paper but no ink is on the paper
I changed paper and now it wont print just spits paper out
Hi
Please turn the roll over. You should now see print out.
Please contact support@star-emea.com for more information.
Star Technical Support.
Jun 21, 2011 | Star Micronics TSP100 Thermal Printer
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
Trying to set up star tsp100 printer as a receipt printer on averasell pos software. Have installed the printer and it prints test page fine. However when I try and do an invoice on averasell the cashdraw...
... For windows 7 YOU MUST go to your printers properties and click the advanced tab and change it from PRINT SPOOL to PRINT DIRECTLY TO PRINTER...
and if you want your receipt to print off to the right size... install a second copy of the STAR TSP100 and set it as (COM3)... (make sure in the properties you change the paper size to 72 X receipt and cut to partial) i'd do it on both copies
as well go in to the virtual port config and add COM 3 and COM 4
then go to the averasel station properties and set cash drawer as com 4 with the generic/text printer and then under invoices set the print drivers as the star tsp100 copy (the one that is on com3)
and set the actual printer as Star Tsp100(the one that is usb)
sorry for the some what confusing step's perhaps someone else can word it better as i do not have the software in front of me right now...
but my end result was a cash drawer that opened
a printer that printed TO THE RIGHT SIZE and not a full page
Mar 28, 2011 | Star Micronics TSP 1000 Thermal Printer
Printer is printing anothing. do i need cartridges(ink) voor this printer?
This printer doesn't use any cartridges or ink.Are You sure you put the paper tape on the right way? If You turn it upside-down, printer won't print anything, since it is thermal printer and uses thermal paper tape, which is "printable" only on one side. Also, check the position of the printer head arm.
Nov 02, 2010 | Star Micronics TSP100 Thermal Printer
Receipt is not printing dark enough. Can barely read it...I thought it was thermal and it shouldn't run out of ink. star tsp100 future print
hello, have you cleaned the thermal head with isopropyl alcohol, and a soft cloth, according to user manual, this should be done, being gentle with it.
Sep 30, 2010 | Star Micronics TSP100 Thermal Printer
Will not print does this machine take an ink roller
NO
Thermal printers use heat to BURN the image onto special paper
Aug 09, 2010 | Star Micronics TSP100 Thermal Printer
Extra Long Receipts
we have Star TSP 700II and it is doing the same. not just 4inches but sometimes it adds extra 20-30 inches blank space. I think it was due to incorrect paper size settings.
Why dont you to go printer properties->Device settings and change the Friction size..as well as set Pagecut to Partial.
Also change preferences under Properties, advanced and change papersize to what suits you .
pl let me know what happens soon
sean
Feb 09, 2010 | Star Micronics TSP100 Thermal Printer
Trying to use star sp200 with quickbooks pos and keep getting spread out printing
Sounds like the "template" is set for "letter size" paper rather than "receipt" paper.
Go to "Workstation" Preferences, and then "Printing". Verify the template selection.
Jan 07, 2010 | Matrix Star SP200 Receipt Printer
Star Manufacturing International Star TSP100  Printer Logo
1,470 people viewed this question
Top Star Manufacturing International Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Star Manufacturing International Office Equipment and Supply Expert? Answer questions, earn points and help others
