Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water flow is Very slow coming out
Slow about making ice
  • GE Master
  • 8,220 Answers
Could be you need to give the coils on the bottom a good cleaning.
Water flow is Very slow coming out - 5f76c03.jpgKeeping a good air flow on them coils increases ice production. Check your water filter. It may need to be replaced. YOUR SERVICE MANUAL
Posted on Jul 28, 2010
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
Amana refigator
The ice maker supply line is frozen remove the tray that the ice dumps in and hold a hair dryer aimed at the tray that ice is formed in a tube comes out and fills the tray this line is the one
Aug 09, 2009 | Refrigerators
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
Jun 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Slow ice maker,poor water dispencer flow
If you used a self piercing saddle valve to hook up to the water supply it is probably the source of your problem. These should never be used. You need to install a drill in type which will increase the water flow and probably never clog.
Apr 10, 2009 | GE PSS26SGRSS Stainless Steel Side by Side...
Slow ice making capacity---water flow slow. can not keep up with
Make sure your water source is completely open and your hoses are not clogged.
Feb 16, 2009 | Whirlpool ED5VHGXM Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
