Question about Epson Stylus Photo R200 InkJet Printer
First it said a couple of ink cartridges were low and I did push them to their limits (always have for the 5 yearsI have loved this little work horse) THen the red ink light kept flashing so I loadeda wole new set of inks. The red light won't go off I put in a et of brand new inks. Same situation led light on no prinint the ink cradle lines up then it quits. HELP
  • Susan Campbell
    Susan Campbell Jul 28, 2010
    I have high hopes! will try in the a.m. If it all doesn't become clear I will let you know :-)
    Susan
  • 6,487 Answers
Go to this site and download the exe file and install it you will find the printer like icon on your icons bars then clear the counters restart you printer.
http://www.eserviceinfo.com/downloadsm/8878/epson_stylus%20color%20&%20photo.html
Posted on Jul 28, 2010
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
How do I change the ink cartridges in my Canon MP480? rn_bluediamond@yahoo.com
Step 1
Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
Step 2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
Step 3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
Step 4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands
Aug 11, 2010 | Canon Pixma MP480 All-In-One InkJet...
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error 5 MP210 canon
Error 5 means a problem with the ink cartridges. Try re-seating the cartridges, ensuring the cartridges are compatible with the printer. If this doesn't work, sadly the only solution is to get new ink cartridges. Ink cartridges have a limited life span, and yours may have reached their end.
Jul 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Low ink warning not right. ink is full. What to correct warning?
According to the information on the website, you should be able to press the Stop/Reset switch for about 5 seconds to disable ink level monitoring on the empty cartridge.
Feb 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I can't get my hp 960c printer ink light to stop flashing
Remove the new cartridge, inspect the contacts,usually gold little square,this is how the printer talks to the cartridge, make sure there is no ink on it. Where the cartridge ink dispenser is and where it comes in contact with the cartage holder,try and put a little rubbing alcohol on a q-tip and clean the area,
it sounds like some ink has dried there and is not allowing the new ink to come out. Some printers
have another cartridge that holds the ink cartridge, if this is the case, remove both of them for easy inspection and cleaning. If this does not work or not sure, go to the hp website and put in your model#
and search the troubleshooting tips. If that does not help contact them with an e-mail for support.
Hope you get it working.
Mar 21, 2009 | HP DeskJet 960c InkJet Printer
Read fax in memory MP830
it won't print faxes if ink is too low so it stores them until you replace the low cartridge or cartridges. Don't know if you can transfer to computer. Do it the other way around and go to www.myfax.com I did and I love it.
Feb 24, 2009 | Canon MP830 All-In-One Printer
Canon pixma mp210 and compatable ink cartridges
Try pushing the reset button for about 5 seconds. This has worked for me.
Oct 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
