I have a Netgear WNR2000 that I want to connect to a comcast modem. My pc picks up an ip from the router but the router does not get an ip from comcast. I have tried a manual setup using the settings from my old Belkin router for the Comcast modem. Nothing happens.
  • 550 Answers
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Jul 28, 2010
Can not connect chromecast to netgear wnr2000 v3
You need to follow the instructions of connecting the Comcast to a PC first, and setting it up.
Then you connect it to the PC and access the router wirelessly.
Dec 28, 2013 | NetGear WNR2000 Wireless Router
Then you connect it to the TV and access the router wirelessly.
I got a Netgear wireless router from comcast I did the instructions on the cd, after it was detecting my connection it said that I have a static ip, I talked to comcast and said that is not right that I...
1.call comcast and ask them to put your modem on bridge mode.
2. Once the modem is on bridge mo the internet light will turn OFF
3. connect your comcast modem using the Ethernet cord to the Internet port at the back of your netgear router.
4. connect another ethernet cable from port number 1 from the back of your router and the other end should be connected at the back of your computer.
5. Then go to this website for the instruction to configure your netgear router. it includes screenshots as well for better understanding.
ftp://downloads.netgear.com/files/rp614v3_setup_manual.pdf
Sep 08, 2011 | Computers & Internet
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have internet access when I plug in the ethernet cable from the modem, but when I try to access the internet via the router it says 'connected but no internet access'. What is the problem?
I know it is very frustrating if these things do not work. I am sure that the router is not setup properly that is why it is not working. It says connected because you have a good connection from pc to the router. But the connection from your Netgear router to the modem is not working. There is a possible IP conflict between your modem and router. I suggest changing the IP address of your netgear router to 10.10.10.1 . To do this click the link below:
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
Note: This is the manual for your router. Go to LAN TCP/IP Setup Parameters to change the router's IP address.
Apr 03, 2011 | NetGear WNR2000 Wireless Router
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
Re-Connectivity to Comcast Modem
All you need to do is "MAC ADDRESS CLONING". Access the router's setup page and look for MAC Clone settings. Enable that and clone the mac address of your main PC. After that, perform a power cycle. Turn off the router then the modem. Wait for 30 seconds then power on the modem first, wait for all the lights to go solid then power on the router. That should do it.
Apr 15, 2009 | NetGear RangeMax WPN824 Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Computers & Internet Logo
351 people viewed this question
Alun Cox
David Payne
David Payne
