Question about KitchenAid KUDM24SE Built-in Dishwasher
I dissassembled parts in bottom of KDS-18 to clean. I cannot remember the correct order to re-assemble correctly. Where can I find an expanded diagram showing the order of parts?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
You cant find a pic showing exactly where the parts go but its really not that hard to figure out things only go in there one way
Posted on Jul 28, 2010
Need to locate thermostate un 2002 buick rendevous
3.4L Engine
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  6. Remove the thermostat housing and gasket.
  7. Remove the thermostat.
  8. Clean the mating surfaces.
To install:
Fig. Remove the housing bolts - Image Zoom Link
Fig. The removal and installation of the thermostat Image Zoom Link
  1. Install the thermostat.
  2. Install the thermostat housing and gasket.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  4. Install the radiator hose to the thermostat housing.
  5. Install the crossover exhaust pipe.
  6. Install the air cleaner and duct assembly.
  7. Fill the cooling system.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day and Merry X-mas.
Dec 25, 2011 | Cars & Trucks
Ok i got the first answer to where the water pump was located now please tell me where in the heck is the termastat located and it's difficulty in replacing it...thank troy
Follow the upper radiator hose to the thermostat housing and follow the instructions below.
3.4L Engine
To install:
Aug 09, 2011 | 2003 Buick Rendezvous
How to change thermostat on 2004 buick rendezvous
Hi there, below are the removal/installation instructions for your thermostat.
REMOVAL:
  • Remove the air cleaner and duct assembly.
  • Drain the coolant until the coolant level is below the thermostat.
  • Remove the crossover exhaust pipe.
  • Remove the radiator hose from the thermostat housing.
  • Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  • Remove the thermostat housing and gasket.
  • Remove the thermostat.
  • Clean the mating surfaces.
INSTALLATION:
  • Install the thermostat.
  • Install the thermostat housing and gasket.
NOTE: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  • Install the radiator hose to the thermostat housing.
  • Install the crossover exhaust pipe.
  • Install the air cleaner and duct assembly.
  • Fill the cooling system.
Hope it helps
Jan 12, 2011 | 2004 Buick Rendezvous
Easy way to change thermostat on 2004 buick rendezvous
Hi, below are the removal/installation instructions for your thermostat.
REMOVAL:
INSTALLATION:
Jan 11, 2011 | 2004 Buick Rendezvous
The ice flapper assembly fell off the ice door. I
Yes you are correct,
Kneel down and look up from the bottom, you will see 2 small slots on the bottom, insert a putty knife or screwdriver in the slot and push up hard or twist slightly. If you gently pull on the bottom front while doing this it will help release. Once this is loose you can disconnect the wires. Be sure the frig is unplugged!
Here is a link to the parts breakdown it may help in reassembly.
http://www.whirlpoolparts.ca/parts/fspShowPage.php?model=ED5RHEXNL03&pageNo=12
Apr 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I would like to clean in between the windows on the dooes of the oven. We have a kitchen aid superba double oven
You will have to dissassemble the door to clean between the glass. You may need to replace the gasket material when you do. It can be done but care will need to be taken during dissassembly, marking parts, so that during reassembly the unit will function correctly and not leak heat or cause the tempered glass to break. Good luck. I hope this is helpful.
Nov 12, 2009 | Sewing Machines
How do I remove the thermostat from my 2001 chevy venture
2001 Chevrolet Truck Venture FWD 3.4L SFI 6cyl
Removal & Installation
To install:
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the air cleaner intake duct.
  3. Partially drain the cooling system.
  4. Remove the radiator inlet hose from the thermostat housing.
  5. Remove the thermostat housing bolts.
  6. Remove the thermostat.
  7. Clean and inspect the thermostat housing gasket mating surfaces.
To install:
  2. Install the thermostat housing.
  3. Install the thermostat housing bolts and tighten to 18 ft. lbs. (25 Nm).
  4. Install the radiator inlet hose to the thermostat housing.
  5. Install the air cleaner intake duct.
  6. Fill the cooling system.
  7. Start the engine and check for leaks.
3.9L Engine
  2. Drain the cooling system.
  3. Release the tension on the hose clamp at the thermostat housing and remove coolant hose.
  4. Remove the thermostat housing mounting bolts and remove the thermostat housing.
    Fig. Remove the thermostat housing to access the thermostat-3.9L engine shown
  5. Remove the thermostat.
To install:
  2. Install the thermostat housing and tighten the bolts to 18 ft. lbs. (25 Nm).
  3. Install the coolant hose to the thermostat housing and install the hose clamp.
  4. Refill the cooling system to the correct level.
  5. Start the engine and check for leaks.
I hope help you whit thie (remember rated this help) Have a nice day and good luck.
Sep 23, 2009 | 2001 Chevrolet Venture
To replace rockerarm,do i need to remove the head?first 1 left side facing the car.
You should only have to remove the rocker assembly,the head bolts ussually hold the assembly on,but even if you remove them the head gasket will stay sealed.You'll have to get the torque specs and bolt down sequence,and check to see if its recomended to replace the head bolts.When you dissassemble the rocker assembly lay the parts out in sequece and reassemble in the correct order.Hope this helps.
Apr 23, 2009 | 1984 BMW 7 Series
Kitchenaid dishwasher kds-18
knjjjr what you have is a defective (or in this case) worn out lower wash arm support. No the shaft shouldn't come out. It will need to be replaced. However remember this dw is over 20 years old.
Feb 03, 2008 | Dishwashers
Dishwashers Logo
265 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
