Question about Samsung Digimax i6 PMP Digital Camera
My camera charger is not working.
My charger turns red when it is not in my camera but off when it is in my camera. Also, after I plug the charger in, before I put my camera in, the light flashes first red, then green, then yellow, then back off. Shortly after, it turns red. Shortly after that, if I don't plug the charger into my camera by then, it starts blinking yellow. Can someone tell me what I can do to solve this problem?
SOURCE: Help please, i'm so frustrated!
Take the battery out and wipe the contacts. That did the trick for me after trying anything else!
Posted on Aug 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
SOURCE: red light green light yellowlight red blinking light
My PS3 just died on me yesterday. I think something is going on here
Posted on Jun 03, 2009
  • 161 Answers
SOURCE: ps3 won't power up!!
the Yellow Light of Death has hit your console. you must have the unit repaired...or replace it.
Posted on Jun 11, 2009
  • 64 Answers
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
Posted on Aug 15, 2009
I have a jazz hdv188 i just bought from a friend who didnt have a charger and i have a motorolla phone charger, the charger turns the light on to red blinks for a few seconds then shines red continually, I...
according to the manual guide, you cannot use another recharging, only the recharge that came with the camera, because you can get a problem on the screen.
you have to use this ADAPTER>
Sunny* SWITCHING ADAPTER
MODEL: SYS1196-0605-W2
PART NO: SYS1196-0505-W2-C
INPUT: 100-240V-0.3A MAX 50-60Hz
OUTPUT: +5V_-_1.0A
OUTPUT POWER: 5W MAX.
Nov 13, 2010 | Jazz HDV-188 Camcorder
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
My camera won't turn on,Even on the charger
Have you tried regular batteries? Unless...is your charger plugged into a gfi outlet? if it is is the little red button on the outlet pushed in? If it is not, then the battery charger is not working. One of my chargers just went kaput, so that is also a possiblity.
Aug 13, 2008 | Mustek Cameras
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Finepix f10 problem
Plug came off the wall? What do you mean by this, the plug to what exactly the charger? How is the charger camera battery set up? Where is the red light on the charger? More detail please
May 10, 2007 | Fuji FinePix F10 Digital Camera
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Samsung Digimax i6 PMP Digital Camera Logo
62 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
