Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Ice maker i just bought a used whirlpool refrigerator with no mannul and i dont know how to make the ice maker make ice. i dont know if i have to put water in the fridge or do i have to connect the fridge to a hose for it to get water. if u could help that would be great.
    Problem Solver:
  • 11 Answers
The Ice maker requires a connection to a water supply. If you look behind the refrigerator you should see thewater fill valve connection. It is located on the right side on the bottom. A supply line kit can be purchased at a locat home improvement store like lowes or hope depot.
Posted on Jul 28, 2010
How to remove Kenmore ice maker 363.59572994?
I sure hope you got an awesome deal on that refrigerator. I would hate to think they charged extra for the mouse :-) Unfortunately, the ice bucket in this model does not just slide out like your other one did. You should be able to remove the front cover & flap of the ice bucket to reveal the ice maker and yes, it is bolted in. below is an exploded parts diagram of the ice maker. As you can see, the whole thing can be taken apart - of course you then have to put it back together. If it were me, I would toss it & replace the ice maker rather than try to disinfect/ sterilize the one in there. Good Luck!!
Jun 05, 2014 | Whirlpool GS6NBEXR Side by Side...
I got whirlpool refrigerator side by side model ED5RHAXNBOO my ice maker sometimes work and some times dont work....I want to know where is the ice maker valve is located to check it.
Go behind the frig. See where the 2 water water lines connect behind the rear panel u removed. That is the water valve. After disconnecting the electricity, u can easily remove it and take it to the parts store for testing.
Aug 22, 2011 | Whirlpool Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hooked up water to icemaker, but it is not filling with water. Bought used; 3 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen and then refils. If there is ice, lift the cut off arm and let it drop to see if it will start.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I just bought the Whirlpool 6th sense refrigerator 25.6 cu with water and ice dispenser. However, I am in a place where I cannot connect to water supply because of quality issues. How do I fill in the...
you have to have water pressure to get water and ice you could get a tank and pump to put your drinking water in or get a good filter for your low quality water
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model ED2CHOXK005 Whirlpool refrigerator with ice maker the ice maker quit working still puts ouf water but no ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Whirlpool Refrigerators
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
