I had a glass of water,and a bit of the water spilt on to my macbook's pad. now the mouse is messed up and it doesn't respond. what do i do, or is there anything i can do?
    Problem Solver:
  • 18 Answers
Turn off the macbook and allow it to dry completely. If you feel comfortable you can remove the touch pad pretty easily to ensure it dries completely. If this does not work your can order a replacement fairly cheaply.
Posted on Jul 28, 2010
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
Aug 26, 2014 | Apple MacBook Air
MOUSE PAD NOT TURNED ON
Re-Boot doesn't help? Unplug, remove battery, plug in AC re-boot.If that does not work boot in safe mode. If that does not work let me know
Oct 29, 2012 | Samsung N Computers & Internet
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
I spilled I tea on my Gateway FX keyboard and mousepad. The keys are working now but I'm worried they will get sticky. I cleaned up as much as possible by patting with a towel to soak up the tea. ...
Before you do anything, unless it is already dried, (turn it off first!) turn the laptop upside down and gently tap the back to coax any liquid out. Then do NOT turn it on until it is totally dried. You can clean the keys and pad it with a DAMP (NOT wet) cloth with plain soap and water. Be careful not to get any water down into the keyboard itself so it doesn't short it out. However this will not clean whatever liquid may have gone inside. Hopefully none did else you could end up with a bigger problem...
Jul 16, 2011 | Gateway Computers & Internet
The pointer moves randomly clicking on everything and i have no control over it.it add folders messes with the screen appeacence,
Try disabling the touch pad and using an external mouse. If this works, then the touch pad is bad. Could be something got spilled on it or it could just be bad.
Jun 22, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
My daughter spilt a bit of cranberry juice on my touch pad. I have a hp. The mouse is working but the left button is a no go and the right one only registers sometimes. What can i do to fix this and make...
Hi, dry it using hair blower to make sure the moist go. To fix your mouse left button, try to unscrew the mouse casing and see to it that by clicking it really contacting with the switch button. Wear and tear also damage the solder of the switch button. it will be fixed by re-soldering the mouse switch if loosen.
Jun 21, 2011 | HP Computers & Internet
When I type on the keyboard there is no response... the letters and commands do not respond. In addition, my mouse sometimes does not respond... I have to click on an item 2 or 3 times before it...
did you get any water damage on this? sounds like the keyboard top had a short. you can replace it with a top case from ebay for around $30 dollars.
does it work with a usb keyboard/mouse?
Mar 12, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Pointer on track pad moves on its own. it does not move along with finger and goes in jerky direction elsewhere.
did water get on the track pad? Try connecting an external mouse to get control over your pointer, and navigate to system preferences/track pad. See if you can play around with the settings, but if the external mouse works ok, it sounds like water may have come in contact with your track pad.
Sep 12, 2010 | Apple MacBook Pro Notebook
Spilt water on mouse. Now red light on
if the mouse is working properly then you might just want to leave it, is it a rechargable mouse?
If you do want to try and fix it , you could try carefully opening it, you should not need to use much if any force and then make sure everything inside is dry, using a hairdryer on low heat can be useful.
there is a chance the water has damaged the electronics of the mouse and so you might not be able to fix the problem.
Oct 30, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Glass water was spilt on it, emerceny download
Listen you must take it immediately to the shop to get it repaired. This says LG if i'm not mistaken so take it to the LG service centre or any good shop because only someone really good can now save your phone. It takes about a week or two for the clogged water to start rusting the components. It's going to happen for sure as the water will not evaporate. The worst thing is your phone will look like it's working fine for a while and a few minor gliches here and there and just when you feel your phone has salvaged the day something will happen. It happened to my moto rokr e8. I dropped coffee on it and after 10 days the screen just went blank. So go to a service centre and say liquid/water damage and see if it can be repaired before it's too late.
Sep 01, 2009 | LG KU990 Viewty
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
