Question about Kitchen Ranges
Halo.. i my car prado king have a problem.. before one week i had change all my barke pad.. after that i service my car air cond and take off the dashboard.. after the aircond has fix.. my car brake was jam.. cannot go.. so what is the problem? is it because the barke pump?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Do you speak english at all. What you wrote here really seems like you shouldnt be working on anything
Posted on Jul 28, 2010
Hi i have volkswagon passat 2004 V6 automatic but i have 1 problem now i saw the warning sign for FRONT BARKE PADS WORN i don't know how to solve this problem
fit new front brake pads ,well check them first in case a sensor wire is damaged ,then after changing pads the light will go out
Jun 21, 2011 | 2004 Volkswagen Passat
My 2007 toyota prado is having a/c problem. after awhile of switching on, the a/c switch light is blinking and also the recirculating air switch changed automatically to outside air intake switch on....
Check to see if the clutch on the A/C compressor is turning with A/C on max. If not then the clutch is bad or a fuse blown. Check Freon level or have a shop do a leak test. If you replace the compressor always replace the dryer as well
Oct 24, 2017 | 2004 Toyota Land Cruiser
How to turn on a weatherking gas furnance
Make sure the thermostat selector switch (located in the thermostat board by pulling out the front) is on the gas position.
Oct 05, 2009 | Weather King 10AJA3601AH Air Conditioner
Saturn Sl1 1998 Front Barke Rotors and Barke Pads
It's not that hard to replace, but there are some tools that your going to have to buy. If there is a Auto Zone in you're area, you can buy the brake pads and may be a new brake rotor if they look to worn out. The rotors are not that expensive any more. They also have the right tools to buy or you can use there tool loner program to get the job done and they have the step by step instructions to replacing the break pads. If you like you can log on to AutoZone.com and look up the instructions to replacing the brake pads on your car. Good luck and hope this helps. Keep me posted, be glad to help.
Jun 16, 2009 | 1998 Saturn SL
Too much play on front brake, 2002 road king
Its not your pads min thickness is 0.04..you have air in the lines or a loose fitting. You really need a vacmum suction device to bleed harley brakes not the old auto turn the nut pump the valve routine. Take it to a shop and have it done will only take about 15 min. Maybe someone prior to you mixed dot 4 and dot 5 maybe it fluid just needs to be replaced. but its not your pads the brake fluid makes up for the pad thickness.
May 07, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Defrost Cycle Problems with Heat Pump
That's what a heat pump does. The problem to me sounds like you don't have a big enough heater inside.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 30, 2017 | Weather King 10AJA4201AH Air Conditioner
Prado high rpm
just besides the air filter over the air intake there is small screw rotate it anticlockwise and see if the rpm comes down or else change the iac (idle air control motor) immediately.
Nov 12, 2008 | 1996 Toyota Land Cruiser
Rear brakes
Did you open the brake lines to squeeze the piston back. If you did you need to bleed the brake system there is air in the system. Good Luck
Jun 21, 2008 | 1998 Toyota Land Cruiser
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
