Question about ATI RADEON 9200 Graphic Card
Im using a flat panel monitor conected via hdmi cable, and the screen goes black occasionly
    Scholar:
  • 83 Answers
From your question it seems that there is some fault in your hdmi cable try to change it.
For any other help or to thank me Mail on my email Ejaz89@live.com
Posted on Aug 06, 2010
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Aug 23, 2014 | Acer Aspire 5350 5750 5750g 5750z Series...
Alienware x51 Desktop black screen on tv...
You have to enable HDMI on the TV and the Computer
Jan 30, 2014 | Sylvania Televison & Video
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
My motherboard and monitor have hdmi ports and a hdmi cable connecting them. When I sellect hdmi mode on the monitor, the screen goes black and then a message comes back saying no hdmi signal. Is there...
Hello, I'm not sure about the system or monitor that you're using, but usually for Windows systems, you have to change the display within the system before the screen will actually show on the monitor through something other than the standard display port. If you reply with your OS, then I might be of more help, but assuming you have Windows 7, you must plug the hdmi cord in, right-click on the desktop, and select Screen Resolution. Then select the option (likely "HDMI") under Display that you are currently not using. At this point, your current screen will most likely go black. Switch you monitor to hdmi mode, and then you should be able to use your monitor via HDMI. If you have any questions, please feel free to contact me, or simply comment.
Feb 17, 2011 | Computers & Internet
No laptop display on television
adjust the tv resolution to near to that of monitor's.use the compatible hdmi cable and also go for display options.
Dec 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
The sreen is black, and the monitor light is orange
This usually indicates an input problem. There are number of things to check:
Make sure the screen is plugged into a working output on the video card - if you can, test the video with a different screen.
Try a different cable; Swap for the same type of cable, or, if available, use a different output method(Such as HDMI).
If using an adapter on the cable, try using a different adapter.
Test the cable on a different display, if possible.
Ultimately, if the video card, cable, and connector are all working, or the display is still not, its likely a bad input board within the display - if you're savvy and have some time to kill, replacement boards cost between 20-70 bucks on ebay.
Feb 10, 2009 | NEC-Mitsubishi Nec Display Solutions...
Insignia 42" black screen and line problem
Insignia and Geek squad has no other solution exvcept 1080i
Dec 26, 2008 | Insignia 42" LCD Flat-Panel HDTV
ATI RADEON 9200 Graphic Card Logo
87 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
