Question about Carrier 38BRC060 Air Conditioner
My air conditioner has 2 zones. It does not open the proper vents when turned on. What can I do ??
  • 674 Answers
Make sure the zone dampers are connected to the correct zone in the controller. Let me know what you find.
Posted on Jul 28, 2010
Can I manually open something to direct cool air into the vents of my 2000buik lesabre.. The air conditioner works I just need to open up a door or something.. I was told
If air is not coming out of your air conditioning vents when the system is on, the BLEND DOOR is not open. This isn't something you manually open, it is automatically opened by a vacuum motor (when it is working). If it is not opening properly, it is usually because a vacuum line has fallen off or broken under the dashboard, or there is a plenum vacuum leak somewhere, sufficient to reduce the vacuum to the air conditioning system that it cannot function properly.
If you hear a sucking/hissing sound under the dashboard, you can find the noise to find your vacuum leak.
May 22, 2015 | Heating & Cooling
I have a Honeywell EMM-3 Electronic MiniZone Panel and my thermostat is set at 78 degrees but the house is registering at 89 degrees and it won't cool down although the a/c has been on all day for...
Zoning, in the A/C world, refers to different areas of the house which may be cooled to different temperatures. Zoning is accomplished by closing/opening vents.
Zone 1, 2, 3 etc. do not have any particular meaning, except to indicate zone control flappers 1, 2, 3 etc. which are physically inside the ductwork which determines the zoned area.
Just because you have this fancy thermostat, does not mean that your house is actually zoned, but I am not to sure why such a thermostat would be purchased if it was not (unless it was free).
Zoning uses dampers. Is there air blowing out of the registers?
:o).
Jun 04, 2011 | Heating & Cooling
My central heating is turned on but not warm air is comming out of the vents
It may be zoned and the zones are not enabled or the fan may be gone in the unit. Read documentation, contact installer or call serviceperson.
Nov 05, 2010 | Intertherm P3RA-048K Air Conditioner
Central air was added to pre-existing ductwork...when the 2 lower zones close and the upper floor zone is open, it results in whistling noise in the 2 lower zones. I beleive this is due to the size of the...
Hi, You need to have a bypass installed that has a wieghted damper on it so that it will bypass the extra air when the other zones close...that also means that you need a duct sensor to shut down the comprassor to keep the coils from freezing up...it gets a bit complicated, but can be done...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 16, 2010 | Carrier 38CKC036 Air Conditioner
I have a 2004 Chevy Tahoe with dual zone air conditioning plus rear air conditioner. My problem is on the 2 driver vents only it keeps going from cool air to hot air. After you drive for a while it is all...
If the truck has a dual zone temperature control in the center console then this is most likely your problem as alot of times when these go bad the think the driver side is too cold and turn the heat on to warm it up thus giving you warm air through the vents on the driver side.
May 27, 2010 | Heating & Cooling
2000 ford taurs a/c dont work it blows cold when i power up the compressor.its running 45 lbs on my gage on the low side.
Hi...
Perform the following basic Checks and Information
1. Check Drive Belts,If belt is intact proceed to the next step.
2. Check for Compressor Clutch Engagement - Turn the air conditioner to the "on" position and set controls to the coldest setting. Start the engine and allow to idle. Then open the hood and inspect the clutch at the front of the compressor, is it turning? "Engaged" if so, the system has enough refrigerant to activate. If the system is low on refrigerant it will not work properly. In this case an air conditioner recharge kit is needed to recharge the system. If the compressor clutch is not turning proceed to next step.
3. Inspect for Refrigerant Leaks
4. Check under dash panel and under hood power distribution center
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the vent door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, inspect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor.
Thanks
Smith
Jul 31, 2009 | 2000 Ford Taurus
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner
filters blocked or fan cage full of dust cant pickup the air if this is a zoned system then maybe zone damper is stuck not letting the air through
Jun 20, 2009 | Sunpentown WA-1210E Air Conditioner
Heater air conditioner unit does not expel air
unless you have zones installed i.e. day and night you will probably find that the main duct off the unit has fallen off
Jun 15, 2009 | Heating & Cooling
Carrier 38BRC060 Air Conditioner Logo
83 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
