Question about Sharp Zaurus ZR-5700
How to transfer Sharp Zaurus 5800 data to mac osx leopard?
    President:
  • 567 Answers
Hi you can use Bluetooth, or if you have the cable to connect from the Zaurus to the computer you have make the connection and make sure the computer recognize the Zaurus before you can do any transfer.
Posted on Jul 28, 2010
I HAD a Sharp Zaurus 5800 PDA. I also had the Zaurus address book backed up in Windows XP. I upgraded to 8.1 but can't find the address book. The Rupplynx 6.2 CD I have doesn't work with 8.1. I know t
Hi
Was the backed up version of the address book openable by WinXP or one of its programmes? If it was you may be able to run WinXP as a virtual machine on Win8.1, otherwise you need to find a programme which will open the address book file or import it in a form that makes sense. This may not be easy !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Sharp Zaurus ZR-5800
I lost my old Sharp Zaurus ZR 3000 K-PDA data when I changed its memory battery. The Zaurus software disks (Win. 95) were useless after I moved up to WinXp, and now are lost. Any idea how could I transfer...
It was ages ago I used my ZR5800. Looks like the 3000.
I only have the device and some old flash cards. Most of my data was coppied to the flashcards. I lost my manual, but I'm sure you could connect by infra red to a laptop. or another IR device.
The flashcards worked in the old laptops, so if you have an old laptop, check if you can put the flashcards in and if you can connect via IR.
Oct 30, 2013 | Sharp Zaurus Computers & Internet
ZR-5800 won't restart
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 10, 2012 | Sharp Zaurus ZR-5800
While trying to transfer data from my Zaurus ZR-5000 to my computer a message comes on my computer screen saying " the Win 16 Subsystem has insufficient resources to continue running. Click OK, close...
You may be short of memory due to too many programs running in background. Google "windows task manager" to learn how to control startup programs. It is not too complicated.
Dec 03, 2017 | Sharp Zaurus ZR-5700
Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
Jul 22, 2010 | Olympus P-440 Thermal Photo Printer
Sharp wizard. Batteries dead. can you retrieve information???
Depends. The Wizards had backup battery. As long as it is still good, then your data is safe. if you saved / copied / made backups to the compact flash card (Type 1 option) as well, then you have a copy there that you might be able to use in a computer. Sharp used a different, not quite proprietary, format for storing data though. You may be able to see the data on the computer, but won't be able to open the individual files.
If your backup battery is dead, and the main batteries are dead, and you don't have backups on CF, then your data is likely gone.
Jun 23, 2010 | Sharp Zaurus ZR-5800
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
Memory back up card for Zaurus 5800
My Zaurus 5800 shuts itself off even when on AC current. Never did this before. Do you know why?
Jun 05, 2009 | Sharp Zaurus ZR-5800
Sharp Zaurus ZR-5700 Logo
205 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
