Question about Hitachi VME545 Camcorder
Audio and video
When trying to view on my tv from camera I don't get any audio also the
video just shutters like up and down
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
If you are in record mode, and you are aiming your camcorder at the TV, you are going to get lines across the screen because the TV and camcorder have different frame rates and you can see this difference when you record a program through the lens of the camcorder. You need to have a camcorder and TV that have the same frame rate, but I don;t think that is viable for the home.
Posted on Jun 04, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
I am from bangladesh the problem associated with my camera is that the display dont show the view of the subject that iI want to capture and the resultant is the no picture only shows the black sheet in...
The S2 IS is a very nice camera, but is known to be susceptible to stuck shutter problems. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 12, 2011 | Canon PowerShot S2 IS Digital Camera
Shutter will not open every time i take a photo. The photo always comes out black on the view finder
Aug 27, 2011 | Cameras
When I turn on the camera 2 take pictures the display screen and the the view finder is black.
Are the pictures taken by the camera also black? If so, a stuck shutter is another common failure mode for digital cameras (particularly for the S2 through S5 IS model cameras). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 15, 2011 | Canon PowerShot S51S Digital Camera
The screen is black and if I take a picture it is also black, I can view older pictures that have been taken
Jul 31, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Panasonic camcorder, recording on tape, and wish to view on my Sony Bravia KDL TV. We bought a S-video cable but are still unable to figure out how to view on the TV. Any help?
Not sure what year your set is but These don't have S video cables anymore. They use component and HDMI as well as the standard audio video cables. What you need is a cable that fits the DV out on the camera on one end and a component or audio video (Red White and Yellow) on the other to plug in your set. try Radio shack or your Local Sony dealer. I have found these on E bay for much less than what the Sony stores will charge. There are even sitch boxes that have several variations of connections that can be used.
Jun 28, 2011 | Sony Handycam CCD-TRV21 Camcorder
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
Hitachi VME545 Camcorder Logo
48 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
