Question about Hitachi 42 in. Plasma TV
I have a Hitachi 42" plasma tv(42HDS52A). While watching, it developed a vertical black stripe sligthly rigth of center from the top to the bottom of the screen. What caused this and what is the fix?
SOURCE: philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Posted on Jul 22, 2008
Hitachi-mex
  • 26 Answers
SOURCE: vertical lines on plasma tv
Maybe is a lose contact in the conectors of the screen.
You need disconect the conectors, clean with isopropilic alcohol, and reconect the conectors.
Posted on Jul 18, 2009
Senco
  • 51 Answers
SOURCE: 42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs
Posted on Aug 28, 2009
  • 36 Answers
SOURCE: 42 Plasma TV has many vertical lines (stripes)
screen itself would seem to be the problem here
Posted on Feb 15, 2010
Highdefjeff
  • 124 Answers
SOURCE: I have a Hitachi plasma model PW1A (42EDT41).
This is not a digital artifact, set-up, or adjustment problem, this is a television in need of repair.
Posted on Jun 15, 2010
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
Oct 21, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Black line in the middle of screen
It is possible the connector to from the address board to the screen may be need to be cleaned & re-seated, but almost 99% of the time this fault is a problem within the plasma screen & the only solution is for a replacement screen.
Aug 14, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Hitachi  42 in. Plasma TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
