Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freazer ices up - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 01, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Probably a bad heater
Posted on Jul 28, 2010
My fridge in my camper wont cool but the freazer is working fine. what do you think? light works and all just wont cool, thanks Lauro
there is a fan that blows cool air from the freezer see if there is ice build up if there is deforst it , if it is fine see if the fan is turning if not the motor went out check to see if wires are loose good luck
Sep 15, 2011 | Electronics - Others
Freazer is makinging anoise
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 26, 2011 | Refrigerators
Ice tray ftlls and never stops rotating then dumps water repeatedly whirlpool model EHD221MTRO
either u bar to shut off is bad, or the flap detectin ice level is in wrong position,..try this, in freazer turn of ice maker, count to 10while dong that move bottom hoizontal armrm back and forth 3 times, turn back on wiat 6 min, c if cycle statrs then
May 30, 2010 | GE GSS22JFMWW Side by Side Refrigerator
THE REFRIGERATOR IS DREPPING WATER INSIDE FROM UNDERNEATH THE FREEZER.
This just happened to me.......in my case - ice formed in a section in the back of the freezer clogging up the place where condensation(?) is supposed to drain off...it has something to do with the frost free feature.....when that became full - water then dripped inside the fridge. I called the manufacturer..they sent someone out who fixed the problem and then put something in the back of the freezer so this would never happen again. Sorry, this isn't a technical response but it sounds exactly like my situation. hope that helps a little.....cost about $200 to fix it...still better than having to buy a new one
May 23, 2009 | GE Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Freazer works fridge warm
Hi Jen, I would suspect the thermostat. The fact that the fan is still coming on and off is because it is more than likely getting frozen or clogged with ice making it stop and in turn cooling stops. Yep I would start with changing the thermostat.
Mar 02, 2009 | Refrigerators
Samsung fridge freezer model no: RS21DCNS
how do we disconnect the water line to the freazer
Mar 24, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
