Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch tvs we have to go to the installation summary and switch the tuner from 1 to 2. i called dish network and they said i would have to have a technician come out and fix it. what happened?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 08, 2011
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
Duo DVD 625 to HDMI
Hi my name is Mike Houston a Social Media Representative at DISH. With our Duo SD 625 DVR, it cannot receive HD signal, there will need to be an upgrade to our HD duo DVR systems. If you have any further questions about our DISH equipment please e-mail me at; michael.houston@dish.com
May 29, 2012 | DISH Network DVR-625 DTV Receiver /...
My Dish DVR 625 does the "program guide download"
Hello! Dan Busa with Dish Networks customer service department. This sounds like it may be a signal issue, I would make sure the cabling is tight and in good condition. You also want to enable your inactivity standby having it disabled will only make this worse. If everything seems ok you may need a technician.
Dec 16, 2010 | DISH Network DVR-625 DTV Receiver /...
I can't pause or rewind my moveie
fktrejo,
When you try to use the DVR features, do you get an error message (024 or 311)? Have you unplugged your 625 receiver yet? If not, unplugged the receiver for about 10 seconds and plug back in. This will cause the receiver to reboot and acquire satellite signal. When the picture comes back on, try to pause. If it still doesn't work, we may need to replace the 625 receiver. I hope this helps.
Ray Calo
DISH Network
Jun 28, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I get closed captioning on my 625 dish dvr.
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
My dvr will not record. We moved the location of the tv and may not have hooked everything back up correctly. I have 2 tvs on this receiver and it will not record on 1 or 2.
dvr's record from the signal input, not from the tv. tv's are just used to display.i expect the input from ariel? sat dish? freeview box? is not connected right
Jan 25, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I migrate my recorded programs from the DVR-625 to my XP pro PC?
It is not possible due to incompatibility, All dish VIp seris recrvs can utilize an external hard drive but is still different format styles from a pc. it will erase all your porgrams whenh you move it from device to device. at this time the USB ports are disable on the 625 DVR.
Oct 11, 2009 | DISH Network DVR-625 DTV Receiver /...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
DISH dvr 625
Its most likely the secondary dish that is used for international programming. Your signal is probably low on that to begin with and during inclement weather goes out completely. A tech will go out at a cost to you and get that repaired.
Mar 19, 2008 | DISH Network DVR-625 DTV Receiver /...
Lines on TV with DVR-625
try using a better cable from the receiver to the tv. sometimes less expensive cables dont "ground " as well as they should after a few years. the more shielding the better. the cable here will sell you the cable much cheaper then going to any store and its better quality, even if your not a customer of cable.
hope this helps
Mar 12, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
96 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
