Question about Olympus DS-4000 Digital Voice Recorder
Memory Error I have an Olympus DS-4000 that is showing a memory error. I looked it up under troubleshooting, but it says the wrong memory card is inserted. However, we have not changed the memory card and it has been working up until now. There is quite a bit of dictation on it that I am trying to download and am afraid of losing it. What do I do?
  • lpike952 Dec 30, 2008
    I have the exact same thing happening. It appears the only solution is to format the card, but i don't want to lose the 20 dictations on there!
    Problem Solver:
  • 6 Answers
I would suggest the XD card is corrupt. You may be able to copy the recording off the machine by copy and paste in windows explorer. If not then they are lost. Data recovery will not work very as the files are recorded in dss format.
Only option is to format the card on the PC.
Posted on Aug 19, 2009
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
How to remove the write protection from olympus voice recorder
The DS4000 has a lock option available from the menu. press the menu and scroll untill you find lock. If you did not prposely lock the file, most likely the files on the memory card are corrupt. You will need to reformat the memory. The format option is in the menu as well.
May 03, 2011 | Olympus DS-4000 Digital Voice Recorder
Olympus DS4000 says Memory Error
I had several cases lke this with clients. One of the dictations is corrupted. It's the "one" here that matters. When you connect the DS-4000 to a PC, it appears in your "My Computer" as a Removable Drive. Browse this drive, and you will find the dictations in one of the folders (A, B, C etc...) or they might be scattered between folder depending on how your user records.
Try to copy dictation manually from that drive to the matching folders on the PC (by default My Documents-->DSSPlayer-->Messages-->FolderA, FolderB..., although you might have changed that).
At some stage one of the dictation files will refuse to copy/paste: that's the corrupted one; however should should be able to save the others. Once you have salvaged all but one dictation, you can do a format of the card. In fact, I suggest you chage the card, as corruption is usually a sign of worst things to come...
Using this procedure, at least only one dictation will need re-dictated.
I hope this helps.
Dec 30, 2008 | Olympus DS-4000 Digital Voice Recorder
Memory Error
You will need a new memory card, 1 gig or less, and not the new HS 1 gig cards. Look for a M type or get a 512 or smaller.
Dec 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS 4000
Try connecting to a differant USB Port. The other possibility is a corruped memory card. try reformating it thru thr recorder menu.
Oct 09, 2008 | Olympus DS-4000 Digital Voice Recorder
My ds-4000 crashes my computers
It's difficult for any techie to diagnose an occasional crash without seeing your computer at the time it crashes. Kind of like going to a doctor and saying "my leg hurt last month. Know why?" Also, you don't say what type of computer you have, PC or Mac.
That said, there are some "first steps" you should take, and, since you own a DS-4000, you should contact your Olympus dealer, since they're obligated to provide you with customer support (although it may not be free):
  1. May sure your software is up-to-date. Get the latest version to make sure you're not the victim of a bug. After you install the update, restart your computer for good measure.
  2. Turn off any applications or task bar tools that you're not using, particularly those that deal with cameras, scanners or memory cards. Adobe Photodownloader is a common culprit, as it interferes with the DS-4000, thinking it is a camera with a memory card.
  3. Update your Operating System. Always. Sometimes, the bugs are not with the Olympus equipment, but with Windows or MacOSX.
Good luck.
Apr 10, 2008 | Olympus DS-4000 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-4000 Digital Voice Recorder Logo
764 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
