Question about HP Wireless Optical Mouse
Wireless hp optical mouse, is green light on
Wireless hp optical mouse, green light on scroll wheel does not work
SOURCE: The Optical Mouse that time forgot
It's a Radio Shack mouse, check this page http://support.radioshack.com/productinfo/ProductResults.asp?Name=Mice&ID=001004001
The item number is 26-753
Posted on Oct 22, 2008
yooperbud
  • 8637 Answers
SOURCE: HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 1602 Answers
SOURCE: Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Posted on Feb 09, 2009
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Posted on Apr 04, 2009
How do I make my scroll wheel work again? It just quit working. Now, I have to click the wheel and move the mouse up or down and it scrolls the page on its own. Nothing happens if I roll the wheel.
If you turn it over you should see 3 or 4 screws in a recess. Sometimes they are covered with stickers. Take the mouse apart and you will see the wheel mechanism and sensors. Clean all the inside with a soft brush.
Or
You could just throw it away and buy a nice new shiny optical wireless mouse.
Did you reboot the computer?
Nov 20, 2015 | Belkin Mini Wireless Optical Mouse...
Installation
Any piece of wireless hardware like a mouse of keyboard usually has a mating switch on it that you press to allow it to mate with the usb receiver plugged into the computer.
Press this and within a few seconds the mouse will work once again.
Dec 10, 2013 | Maxell Safari Mouse - Optical - Wireless -...
Wireless optical mouse 20331 scroll wheel very erotic
Erotic? Does it keep bringing up **** when you roll it? Lol.
I assume you mean erratic... the scroll wheel on mine doesn't work at all. I found your post while looking for a solution for that problem.
Sep 12, 2011 | GE Wireless Optical Mouse
I have an HP N3 optical mouse that was doing well until the other day when the middle little scrolling wheel stopped working. Can I fix it or do I have to buy something else? Thank you.
If the entire mouse stopped it probably time for new batteries. If it is just the wheel then it could be a driver issue or setting. If those are ok ie the middle button wasn't disabled somehow or your computer figured it only has a 2 button mouse then its hardware. That means its replacement time. It's possible the switch or the sensor for the wheel are dirty so if you want to you can take it apart and try cleaning.
Aug 11, 2010 | HP Wireless Optical Mouse Sl/Blk With...
I am using logitech optical mouse it si moving automatically in the desktop.send me the solution
Try the mouse in another computer.
If the same thing happens, then something inside the mouse is "stuck".
Press each mouse button, including the scroll-wheel, if it has one, and listen for the expected "clicks" as you press, or as you scroll.
Jan 04, 2010 | HP Wireless Optical Mouse
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
Dell wireless mouse -- scroll wheel not working
Your very welcome. Since the mouse was definitely defective its cool that Dell is going to replace both for you. If you can please rate me for my help to you I would definitely appreciate it and hope your weekend is a good one.
Ben
May 13, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse is not working properly
I have the same issue and I think this is one of worst product that HP makes.
Feb 18, 2009 | HP Wireless Optical Mouse
Microsoft Wireless Optical USB/PS2 x08-72982 - I just want the wheel to let me scroll up/down. It's very sensitive and pressing it gives me that free-scrolling icon which I don't want. How do I disable...
Jan 06, 2009 | Microsoft Wireless Optical USB/PS2 Mouse...
HP Wireless Optical Mouse Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
