Question about HP LASERJET P1005 Printer
Printer loaded with paper. Printer window reads Out of Paper and wont print or delete current job. How to reset?
  • 52 Answers
If computer says out of paper but printer is in ready state computer does not see printer (conection)
Posted on Jul 29, 2010
"Paper detected does not match paper size. or type selected. Make sure the paper size is correct to continue the job" This is now on the display window. Nno changes were made. Help!
You give no details what job has been sent to the printer before that. Probably your printer settings about the paper are some standard for your area like A4 for example, but you are trying to print a file, received from a place on earth, where the paper used in printers is different format and the file has been prepared for print on Legal, for example. To reset the process, find the print job in your Devices and Printers folder and delete it. Then power cycle the printer. Then check the document and make ajustments to it fitting the printer settings. Then print it again.
May 06, 2015 | HP OfficeJet Office Equipment & Supplies
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Stop Printing
Hi and thank you for using fixya:
To stop your printer from printing while printing press stop or cancel in your printer control center. Also you can click stop or pause on your computer print dialog box,
1-right click on top of the printer
2- click pause on current job printing
good luck!!
Apr 08, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
The printer keeps saying check the paper size when its the same paper , we have been using from a very long time
Confirming/Deleting a Print Job
  1. Press <Status Monitor>.
  2. Press <la.gif> or <ra.gif> to select [PRINT], then press <Set>.
    If there is no job, [NO PRINT JOB EXIST] is displayed.
  3. If you decide to delete the current print job, press <la.gif> for [YES].
    • To cancel deleting the job, press <ra.gif> for [NO].
    • Once the job is deleted, the job cannot be restored.
    • If the alarm light is flashing, open and close the front panel to reset the alarm.
Apr 07, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Wont load paper
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
Paper wont load
Check item 1:
Check item 2:
Check item 3:
HP LASERJET P1005 Printer Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
