Kawasaki D controller Network Setup.
I have a robot cell with 5 kawasaki D-controller. I am very strong in the Slogic programming but I am unfamiliar with KLadder/KLogic which happens to be what this cell uses. Currently I need to use my laptop and connect via RS-232 to communicate with the controller using the KLadder software. I would like to set up the cell to communicate with each robot from the main cpu at the cell. My basic question is....where do I begin? I can't seem to communicate via ethernet from my laptop directly to the controller as it is right now.
  • 121 Answers
SOURCE: Imageteam IT3800 scanner won't hold the config.
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Posted on Mar 09, 2007
SOURCE: Will not detect
Ok well all I can suggest is this... first try a NON-crossover cable.. 2nd.. try the address of 10.1.1.1 The server should be setup according to the manual.. and should be detected upon connection, Also is the server to be set up to ASSIGN an address via it's DCHP or to RECIEVE one from ya lappy? I mean basically it is just a network device that sends stuff when asked, not unlike a networked Hard Drive etc. Usually ya set up the lappy for DHCP and the Video Server gets it's address from the lappy, & when "Polled" sends data to whomever "Polled" it.
Posted on Aug 03, 2007
SOURCE: vpn pass through problem with us robotics model 5461
solved the problem. Had to set DSL modem to bridge mode and then set the router PPoE, provide ISP name and password information and bingo! works!!
izzydog
Posted on Nov 13, 2007
sapperj
  • 70 Answers
SOURCE: maxtor 500g network drive
Describe to me exactly how you are set-up. Include the IP addresses of each device and exactly what ports are being used on each device. Could like an IP mistake or in some cases an X-over cable is still required IF your switch does not have does not have a x-o button on it. But that depends how things are connected. These are the 2 most likely but need the above info to diagnose.
Jeff
Posted on Feb 16, 2008
mlake33
  • 427 Answers
SOURCE: Motorola SURFboard SB4200 With Buffalo Airstation
If it were me, i would return the airstation. then i would buy a linksys WRT54G. They are about 50 dollars. Then use that to set up your wireless network and you will find it quite easy.
Posted on Apr 27, 2008
2010 Kawasaki Vulcan 1700 Classic how to lower the bike
Hi, ELF here are some options for lowering your bike depending on your needs and wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Smaller diameter wheels.
7. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
lowering the 1700 voyager Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN1700 Vulcan Vaquero Suspension Lowering and Setup
Kawasaki Vulcan 1700 Nomad Service Manual
OEM Parts for Kawasaki
2010 Kawasaki Vulcan 1700 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2014 | 2010 kawasaki Vulcan 1700 Classic
1997 Kawasaki ER-5 rear shock adjustment
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Motorcycle Maintenance Adjusting your Suspension
How to Set Motorcycle Suspension Sag by Cycles
KAWASAKI ER 5 Service Manual
http://mybikemanuals.com/kawasaki/kawasaki-uncategorized-owners-manuals
Mar 18, 2014 | 1997 kawasaki ER-5
2001 Kawasaki ER-5 how to remove the water pump
Er5 water pump leaks
Kawasaki ER 500 Episode 28 Water pump rescue
https://www.kawasaki-techinfo.net/showOM.php?view_lang=EN&spec=OC&category=MC&book_no=99986-1029-01&lang_code=EN&code=&nickname=&modelyear=
Feb 03, 2014 | 2001 kawasaki ER-5
2005 Kawasaki ER-5 how to rebuild the carburetor
Carburetor Repair Kit for Kawasaki Er 5 Twister Er500ad 2005 2006
step by step ninja carburetor overhaul
http://www.ownersmanual.biz/2004-kawasaki-er-5-owners-manual
Jan 16, 2014 | 2005 kawasaki ER-5
2001 Kawasaki ER-5 tire air pressure
The Kawasaki 500 at MotorBikeSpecs net the Motorcycle Specification...
https://tirepressure.com/motorcycle/kawasaki/er-5
Dec 03, 2013 | 2001 kawasaki ER-5
2009 Kawasaki Vulcan 1700 Voyager replace the rear shock
Replacing Rear Shocks Voyager Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VULCAN 1700 VOYAGER Service Manual
Kawasaki Vulcan 1700 Voyager Owner Manual
Nov 26, 2013 | 2009 kawasaki Vulcan 1700 Voyager
2005 Kawasaki ER-5 size of float bowl bolts
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Kawasaki ER 5 2005 CARBURETOR PARTS
Supply Motorcycle Carburetors Parts for Kawasaki Ninja 500R eBay
Nov 13, 2013 | 2005 kawasaki ER-5
1996 Kawasaki ZZR 600 strong fumes from the exhaust
Hi, App-3rp65901 and the usual suspects are:
1. Fouled spark plug.
2. Fuel injector stuck open.
3. Carburetor float needle valve, not seating.
4. Carburetor float stuck open.
5. Exhaust valve stuck open.
6. Exhaust valve bent.
7. Fuel valve leaking back through the vacuum line.
Idling issues on 1995 Kawasaki ZZR600
gassy exhaust fumes ZX Forums
Kawasaki ZX6 ZZR600 90 97 pdf
Kawasaki Ninja Owners Manuals
Aug 10, 2012 | 1996 kawasaki ZZR 600
2004 Kawasaki KLR 650 surging
Hi, Prezz_99 and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
https://www.klr650.net/forums/showthread.php?t=3271
bike surging at low rpm
Kawasaki KLR650 Service Manual
2004 Kawasaki KLR650 Owner Manual
Aug 27, 2011 | 2004 kawasaki KLR 650
Computers & Internet Logo
101 people viewed this question
Alun Cox
David Payne
David Payne
