Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispensor and door water stopped working - GE (PSS26MSRSS) Side by Side Refrigerator
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Check voltage at valve on back of fridge
Posted on Jul 28, 2010
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Ice and Water Dispenser on door stopped working
Sounds like the dispensor board has lost communication with the main control board . The part number for the main board is WR55X10942 . This is the board behind the refrig , behind the small 8 X 10 panel . It runs about $ 150.00 . I have never found a bad dispensor board . The main board is easily replaceable .
May 26, 2010 | GE GSS25LGM Side by Side Refrigerator
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
No water from dispensor in door.
Ice supply line is frozen in the freezer door. Using a hair dryer with the door open you have to thaw the line. This will take time but this will fix.
Feb 01, 2010 | GE GSS25LGM Side by Side Refrigerator
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
